planemad
Joined: 05 Nov 2008 Posts: 226 Location: United Kingdom
Posted: Fri Oct 09, 2009 5:16 pm Post Subject: Shed Cable Install Advice |
Hi
I'm going to lay a cable down to my shed this weekend.
My sparky has done the calcs and has told me the cable size and all that.
The run is 12metres underground and he has said 4mm cable.
I will be going into the side of the shed with the cable by drilling through the wood.
Is there any type of adaptor that will finish of the cable entry into the shed that will remain waterproof? |
Aragorn84
Joined: 03 Sep 2008 Posts: 333 Location: West Lothian, United Kingdom
Posted: Fri Oct 09, 2009 5:25 pm Post Subject: |
I presume your using SWA?
The cable when it enters your shed can be sealed up using standard silicone sealer or similar.
The cable will need to be properly terminated into a box, so all you'd be doing where it comes thru the shed wall is sealing the cables outer jacket onto the wood. |
planemad
Posted: Fri Oct 09, 2009 5:30 pm Post Subject: |
Will be using SWA, I also have some flexi nylon conduit that I found in a skip at work that I will also run the SWA in.
I don't think its necessary but it a bit more protection I suppose. |
chapeau
Joined: 02 Oct 2007 Posts: 175 Location: Nottingham, United Kingdom
Posted: Sat Oct 10, 2009 7:21 am Post Subject: |
I'd be more tempted to run the conduit in the same trench empty apart from a draw wire it it. So if in the future it was desirable to run other cables down there (eg network, alarm, phone etc) you have somewhere convenient to put them. |
TicklyT
Joined: 30 Jul 2006 Posts: 1873 Location: Hampshire, United Kingdom
Posted: Sat Oct 10, 2009 8:31 am Post Subject: |
If possible, I would be looking at ways of bringing the cable through the floor of the shed, so any waterproofing issues disappear __________________ If it isn't broken, keep fixing it until it is |
