Worcester Bosch 240 combi boiler fires and cuts out
18 Jun 2008
Glasgow
I have a Worcester Bosch 240 combi boiler. It is firing but immediately cuts out.
I'm in a soft water area and the Diverter valve was replaced just over a year ago.
Here's the symptoms:
Regardless of rad valve positions or hot water demand boiler won't run,
Honeywell reset button trips,
Pressure gauge at 0.5 bar when cold,
All rads bled and OK,
No leaks identified.
When honeywell is reset, burner fires up to the sound of loud gurgling in the boiler, pressure shoots up to 2.0 or 2.5 bar then burner cuts out, honeywell trip.
Doesn't fire up for hot water either.
Any suggestions would be gratefully received.
:confused:
check pre charge presure in expansion vesell aswell this will explain the pressure problem
and what petit pablo says
It sounds as if you have two faults!
The first is easy to diagnose and correct. See the FAQ about expansion vesels, either failed or needs repressurising.
The rest of your post is not consistent! For the pressure to increase the boiler would have to be firing for at least a few minutes, buts thats not what you have said.
Could you be a little more informative and then I can identify your problems.
Tony
try topping the boiler above 0.5. to 1
Hows that going to help when the pressure is jumping up to 2-2.5???
Obviously a problem causing the pressure rise and burner cut out.
This doesnt sound like normal heating expansion.
HW microswitch could be stuck
by the way davebgas. have you moved country or is it time i really need to sleep it off :confused:
Fancied a change of virtual scenery, stay elusive and all that ;)
Thanks folks,
Have isolated gas supply and reset honeywell.
Not a lot going on, pump doesn't appear to be running but pump heats up, too hot to touch.
Looks like pump needs replaced???
:confused:
