minimum width of partition wall?
5 Aug 2008
Berkshire
hi
i want to turn 1 room into 2 and keep as much space as possible. whats the thinnest i can have the partition wall? noise insulation isnt an issue, does that mean i can have it thinner than 'normal'?
thanks
the amount you can save is so miniscule like about 12mm per room that will then stop you hanging things from the walls as they are now too thin
better planning like beds raised up to allow storage underneath
or the use off cupboard/wardrobs side by side but open to opposit rooms to form the walls /partitions
i am assuming you have a window and entrace door to share!!!
have you got a drawing or sketch so i can advise!!
Despite what people will tell you on here, you can construct a partition wall with 25mm battens and 12mm plasterboard each side. I know this for a fact as the house I live in has these walls. Provided you don't want to hang shelves or a big Flat screen off them that is. A picture or a clock won't fall off the wall though. Realistically though, you're only going to lose 50mm if you use 75mm studs which will be more than adequate.
63 x 38 CLS used "sideways" and 12.5mm boards and 3mm skim - so thats 69mm thick - and its solid
You could use [lots of] 25mm battens, but I'd be concerned as to how straight they are and fixing to them, and it may be time consuming to actually build and mess about with
