two showers off one pump
30 Aug 2006
Tyne and Wear
I have a mira select shower in a cubicle right next to cylinder cupboard but the pressure is rubbish, i plan to fit a pump and surrey flange in the cylinder cupboard. Would it be ok to take two tees off the pump to another shower in another bathroom (pipes would go into the loft and back down to new shower) What pump do i need and should these pipes (from the 22mm tees to the other shower) be 22mm or would 15mm do ? Thanks in advance.
aye under the swing bridge :LOL:
yes it can be done would think 22 would be best
pumps most of the mans do booster pumps now
mira
stuart turner
newteam
triton
btw they are suggestions not recomendations ;)
If the pipework goes up and back down put manual air vents at the high point.
It the pipes go into the loft, get an negative head pump, or a whole house pump.
And make sure the storage tank is large enough to supply both.
