DIYnot
Local | Network
   DIYnot > Forums
Local | Network
felt backed carpet: Use underlay?
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
Author Message
seagull
from United Kingdom
PostPosted: Tue Jan 18, 2005 5:54 pm Reply with quote
I thought felt backed (not foam backed) carpet didn't need underlay? The bloke in Carpetright says it's best to avoid lines from the floorboards but is he just trying to get some extra cash? Does it depend on how uneven the floorboards are?
Thanks for the help.
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 117 times
PostPosted: Tue Jan 18, 2005 7:54 pm Reply with quote
Depends how good your flooring is and butted together but you will get slightly movement of each edge of flooring unless they are T&G flooring. You may find the underlayer plus carpet foam backed too soft. I think the best way is to put down sheet of hardboard with a staple gun. Will also prevent draught under floorboard if it's on the ground level.
Back to top
 Alert Moderators
seagull
from United Kingdom
PostPosted: Thu Jan 20, 2005 9:35 am Reply with quote
Many thanks
Back to top
 Alert Moderators
seagull
from United Kingdom
PostPosted: Thu Jan 20, 2005 9:54 am Reply with quote
Do I use tape then?
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 117 times
PostPosted: Thu Jan 20, 2005 10:00 am Reply with quote
seagull wrote:
Do I use tape then?
I take it you mean the hardboard joint then it would be a good idea to stop the edge lifting.
Back to top
 Alert Moderators
seagull
from United Kingdom
PostPosted: Thu Jan 20, 2005 2:02 pm Reply with quote
Sorry. No I meant the felt backed carpet - does this need to be stuck to the hardboard?
Thanks again.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
Felt backed carpet onto underlay and spikes from gripper 3 1300 Thu Jan 26, 2012 7:25 pm
Felt backed carpet 4 220 Fri Mar 16, 2012 6:59 pm
fitting felt backed carpet 3 11660 Mon Nov 24, 2008 6:54 pm
felt backed carpet - laying onto plywood or similar? 6 1580 Mon Feb 08, 2010 4:44 pm
Felt Backed Carpet 9 19080 Tue Feb 01, 2005 6:04 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
