Microbore trunking
15 Oct 2009
Cornwall
I am currently installing a 10 mm microbore system in my 1 bedroom flat. Is there any trunking for such pipe to mount externally onto bathroom tyles as i do not want to chase walls/ retile.
I am planning to screw 25 x 16mm mini trunking to the wall which will accomodate the pipes but i am concerned with the heat and how to secure the pipes within.
any advice be great
1 do the job right
2 if you must, do it
3 the covers will go brittle with the heat over time
4 drill the back first before fixing as it will break
5 you can get cable tie clips that fit it
good luck :cry:
cheers mate. girlfriend just forked out for new tiling so must be surface mounted, Any alternatives to my suggestion?
