DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Hard brake pedal
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance
Author Message
dickiem
from United Kingdom
PostPosted: Sun Oct 18, 2009 6:11 pm Reply with quote
I have a 1999 Peugeot Partner van with a brake problem.
Over the last couple of days I've noticed the brake pedal become hard on several occasions. First time I noticed was when I set off from cold to do a 3 point turn and the pedal felt hard. Second time, i'd coasted a short distance in neutral and when I applied the brakes the pedal was hard. Third time, I was braking from about 40mph coming to a junction and the pedal gradually became harder. Sudden braking gives a normal pedal and good stopping power. Pedal feels fine if the engine has been revving a bit but seems to go hard at nearer tick over RPM...any ideas?
Back to top
 Alert Moderators
JonB
from United Kingdom
Thanked: 24 times
PostPosted: Sun Oct 18, 2009 6:14 pm Reply with quote
Not a pro but sounds a bit like the servo needs checking.
Reason being, if the engine is not running the pedal will go hard, when running the pedal gets softer. If that makes sense.
JonB
Back to top
 Alert Moderators
dickiem
from United Kingdom
PostPosted: Sun Oct 18, 2009 6:17 pm Reply with quote
That was a thought I had JonB but not sure where the servo is to check, last time I checked a servo the brake master cylinder was fixed to it but that doesn't seem to be the case on the van icon_redface.gif
Back to top
 Alert Moderators
Burnerman
from United Kingdom
Thanked: 2464 times
PostPosted: Sun Oct 18, 2009 6:21 pm Reply with quote
The vacuum for the servo is provided by a pump driven from the nearside end of the camshaft...check for pipes split, missing etc. To check the servo - engine off, press the brake pedal a good few times - it will rise to the top. Keep pressure on the pedal then start up. The pedal should fall a bit if vacuum is being supplied to the servo. Cheers John
Back to top
 Alert Moderators
dickiem
from United Kingdom
PostPosted: Sun Oct 18, 2009 6:25 pm Reply with quote
Burnerman wrote:
It is a diesel John yes, I will check the pipes tomorrow. So where is the servo on these things...is the master cyliner not mounted to them nowadays?
Back to top
 Alert Moderators
KingboyD
from United Kingdom
Thanked: 43 times
PostPosted: Sun Oct 18, 2009 6:40 pm Reply with quote
Check the vac pump is sucking, if it isnt before you replace it check the oil feed to it, if its getting a good supply of oil then its prob new pump time.
Back to top
 Alert Moderators
dickiem
from United Kingdom
PostPosted: Sun Oct 18, 2009 6:48 pm Reply with quote
Thanks guys, will have a look tomorrow night...hope it's something simple...and cheap icon_biggrin.gif
Back to top
 Alert Moderators
Burnerman
from United Kingdom
Thanked: 2464 times
PostPosted: Sun Oct 18, 2009 7:27 pm Reply with quote
Aye, the master cylinder is bolted direct to the servo. Hopeless to get to though icon_confused.gif John icon_smile.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance All times are GMT
Page 1 of 1
Jump to:
clutch pedal hard to push 5 920 Tue Jan 22, 2008 5:31 pm
DIY Hard Brake Line Flaring 2 160 Mon Aug 06, 2012 7:41 am
citroen synergie hard to start 3 1700 Mon Jun 18, 2007 8:34 pm
Ford 1.8 diesel L reg / hard to start in mornings ........ 2 920 Sun Jan 22, 2006 1:22 am
1.5 dci micra 2003 hard start!! 2 340 Mon Mar 15, 2010 10:28 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
