DIYnot
Local | Network
   DIYnot > Forums
Local | Network
slight shock off the kettle or dishwasher
Goto page 1, 2, 3  Next
Author Message
tinbucket
from United Kingdom
PostPosted: Mon Oct 26, 2009 4:08 pm Reply with quote
I've got about 100volts running through the earth from somewhere localised to one corner of my kitched. If i touch the kettle with a wet hand, or a cut finger, i get a bit of a shock - nothing major, but bloody annoying. any clues on how to trace it. it happens with barefeet touching a nail that holds the wooden floor to the concrete subfloor.
the diswasher and kettle are not in the same socket.
Noticed sunday an earthing lead hanging loose beneath the kitchen cupboards.
A very mild current running through the cold water tap also not uncommon. Dishwarsher plug is beneath the sink, the kettle socket about 2 foot from the sink.
any clues on how to trace / remidy this would be great. many thanks.
Back to top
 Alert Moderators
PrenticeBoyofDerry
from United Kingdom
Thanked: 1757 times
PostPosted: Mon Oct 26, 2009 4:24 pm Reply with quote
I think your best employing an electrician to find the fault, you said a voltage of 100Volts, out interest how do you know that?
It's more than enough to kill you, you've been lucky so far. Isolate the circuit and get someone in pronto.
Back to top
 Alert Moderators
tinbucket
from United Kingdom
PostPosted: Mon Oct 26, 2009 4:45 pm Reply with quote
It's been like it for a good number of years now. Yes, I know that's a dreadful state of affairs. and hell of a dodgy state to be in... Probably a wake up call..
As for how i know, I stuck a multi meter in the earth pin of the kettle socket and to a nail in the floor repeated it with the dishwasher one on the internal casing of the d/w and to the same nail. The new dishwasher does the same, but lesser voltage - about 70. repeated the exercise with the earth pin and the neutral pin.
The flooring nails have been insulation taped to prevent the bare foot problems, but embarrassingly no cure I know. Thanks, for the sage advice.
Back to top
 Alert Moderators
mikhailfaradayski
from United Kingdom
Thanked: 86 times
PostPosted: Mon Oct 26, 2009 5:15 pm Reply with quote
hhmm,
voltages on exposed metalwork,
been like it for years,
Do you really need anybody to insult your intelligence by saying you need an electrician ? C'mon, even you know its the totally obvious answer!
Back to top
 Alert Moderators
Johnmelad502
from United Kingdom
Thanked: 49 times
PostPosted: Mon Oct 26, 2009 6:09 pm Reply with quote
mikhailfaradayski wrote:
hhmm,
Could be he can't afford an electrician so has asked a question on a DIY forum so that he can try and find the fault himself, DIY = Do It Yourself. icon_lol.gif
Back to top
 Alert Moderators
disinfo
from United Kingdom
Thanked: 14 times
PostPosted: Mon Oct 26, 2009 6:13 pm Reply with quote
With a signature like yours, i'd have thought you would have realised why this may not be appropriate.
Back to top
 Alert Moderators
ricicle
from United Kingdom
Thanked: 377 times
PostPosted: Mon Oct 26, 2009 6:17 pm Reply with quote
GET A COMPETANT ELECTRICIAN IN NOW IF YOU VALUE YOUR'S OR YOUR FAMILY'S WELL BEING !
Back to top
 Alert Moderators
Johnmelad502
from United Kingdom
Thanked: 49 times
PostPosted: Mon Oct 26, 2009 6:29 pm Reply with quote
AND IF HE CAN'T AFFORD IT?
There are people out there (really) who getting 100 together would be about as easy as you or me getting a million.
Back to top
 Alert Moderators
eniacs
from United Kingdom
PostPosted: Mon Oct 26, 2009 7:00 pm Reply with quote
Come on guys - if your electricians help this guy out - this is a diy forum not another place for you pros to come and suggest he call in some scumbag with a 17th ed ticket who will charge 40 an hour for a job this guy could do with his multimeter!
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 864 times
PostPosted: Mon Oct 26, 2009 7:09 pm Reply with quote
The multi-meter will give some readings of voltage etc etc.
The interpretation of those readings requires some knowledge to arrive at what is possibly the fault. Then the fault has to found and then be repaired.
So far three possibilities.
[1] The nail is partially earthed through damp timber and the washing machine is live.
[2] The washing machine is earthed and the nail is live via damp timber to a damaged cable or concealed, damp and corroding junction box.
[3] The washing machine is NOT earthed and the nail is also live.
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 1022 times
PostPosted: Mon Oct 26, 2009 7:11 pm Reply with quote
Or a failed joint on the PME network....
Back to top
 Alert Moderators
martinxxxxxx
from United Kingdom
Thanked: 56 times
PostPosted: Mon Oct 26, 2009 8:43 pm Reply with quote
If there are loose earth connections turn off the mains to the kitchen and sort them out first.
If the fault is still there then please call someone electrical to at least advise you. A couple of tests should be all it takes to asses how dangerous the fault is.
By the sounds of it. If someone were to wash up with bare feet and stand in a puddle in your kitchen it would be the absolute last time they ever washed up. I am not trying to scare you and I can show you the sums to prove it would be so.
Take care
Martin
Back to top
 Alert Moderators
ricicle
from United Kingdom
Thanked: 377 times
PostPosted: Mon Oct 26, 2009 8:48 pm Reply with quote
martinxxxxxx wrote:
If you find you have any readings above 2 Ohms then your have proved that you have a life threatening fault.
Where did you get that little gem from ?
Back to top
The following user says thank you to ricicle for this useful post:
martinxxxxxx (26 Oct 2009)
 Alert Moderators
mikhailfaradayski
from United Kingdom
Thanked: 86 times
PostPosted: Tue Oct 27, 2009 9:01 am Reply with quote
That would be unfortunate, but how would you propose to help someone via an internet forum for a problem like this? (without killing him)
What he describes sound potentially lethal. If he were your family, would you be happy with this course of action to find the problem? How do you know he is actually describing the fault in its fullest accurate detail? (no disrespect to the OP)
Back to top
 Alert Moderators
mikhailfaradayski
from United Kingdom
Thanked: 86 times
PostPosted: Tue Oct 27, 2009 9:08 am Reply with quote
HI Eniacs,
Care to lead the way on resolving this problem?
some of us 17th edition scumbags can cut straight through the B/S and can tell that the services of a professional scumbag is required.
Consider this, if this were the NHS direct and the question was
'got a bit of a cold, what can i do?'
im sure the online answers would be forethcoming.
If the question was, 'im bleeding copiously from the ears and eyes, what can i do?'
the only sesnible answer would be something like 'go to the hospital, double quick, stop messing around, you might die before you get an answer'
Back to top
 Alert Moderators
Page 1 of 3
Jump to:
Bathroom extractor fan (Slight variation on a theme!) 8 540 Sun Sep 13, 2009 9:07 pm
Thought these were slight overkill. but... 13 460 Mon Sep 17, 2012 9:07 pm
A slight twist to Electrics to a shed 12 820 Tue Jul 29, 2008 10:35 am
Oh no! Not another Fan / Dimmer question! (slight twist). 9 820 Tue Jan 17, 2006 6:07 pm
sLIGHT BUZZING FROM KITCHEN TAPS 8 940 Tue Apr 04, 2006 9:45 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
