Master of None
Joined: 31 Oct 2007 Posts: 218 Location: Edinburgh, United Kingdom Thanked: 1 time
Posted: Tue Oct 27, 2009 12:28 pm Post Subject: Router bit runout. |
I have a Ryobi EKT2100V router and have noticed that with a 63mm straight cutter there seems to be around 1mm of runout at the end of the cutter. Seems to be the collet not the cutter because I have tried 3 different cutters. Is this within expected tolerance?
Thanks. |
big-all
Joined: 12 Jul 2004 Posts: 5771 Location: Surrey, United Kingdom Thanked: 24 times
Posted: Tue Oct 27, 2009 12:48 pm Post Subject: |
remove the collet nut remove the collet clean and lightly oil then wipe clean again check for any burrs or creased metal use emmery /very fine sandpaper to CAREFULLY remove
clean oil and wipe clean again reassemble and try
1mm is borderline  __________________ big all
we are------------------ all still learning |
Master of None
Posted: Thu Oct 29, 2009 12:06 pm Post Subject: |
Thanks Big-All.
Already removed and cleaned. However after your post I removed it again, cleaned and checked for burrs. Found nothing but cutter is now running dead true.  .
Its a mystery |
big-all
Thermo
Joined: 21 Oct 2004 Posts: 8453 Location: Sussex, United Kingdom Thanked: 31 times
big-all
