DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Tiling on Plywood
This topic originated from the How to page called Ceramic wall tiles
Click here to return to the page called Ceramic wall tiles.
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
  View previous topic :: View next topic
Author Message
dringeruk
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jan 22, 2005 4:32 pm    Post Subject:
Tiling on Plywood
Reply with quote Thanks
I have just built a new bathroom with the partition walls out of Marine Ply. Although the surface is mainly flat it dips where the screws are. Is it possible to level it with some sort of filler compound or shall i use a deaper layer of adhesive?
John
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
dringeruk
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jan 25, 2005 5:09 pm    Post Subject:
Is there anyone that can answer this question or is it so obvious, that only i dont know the answer icon_redface.gif
Back to top
 Alert Moderators
Thermo
from United Kingdom
Thanked: 31 times
PostPosted: Tue Jan 25, 2005 5:34 pm    Post Subject:
if the indentations are not to deep the adhesive will take care of it.
What is it today with people wanting answers straight away??????????
__________________
have grace to accept what cant be changed, strength to change what can, wisdom to see the difference
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 7 times
PostPosted: Tue Jan 25, 2005 8:28 pm    Post Subject:
__________________
Always judge a man by the way he treats someone who is of no use to him
Back to top
 Alert Moderators
Panjandrum
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jan 25, 2005 11:35 pm    Post Subject:
When you say it dips, do you mean a small indentation like we would expect, or is it something more sinister? Screw holes would easily be accommodated by tile adhesive - and there is no problem to answer. If your marine ply is bending in gentle curves then it's more of a puzzle - and more likely to be impossible - both to understand and to fix.
Back to top
 Alert Moderators
dringeruk
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jan 26, 2005 5:30 pm    Post Subject:
I'll explain in more detail.
The bathroom is about 2.4m square with two walls thermalite block, one wall is a partion and the other is half brick,half partition. Its part of a new extension above the garage. I placed a straightedge on various parts of the walls. There is about a 5-6mm max gap over about 450mm in various places. I assume its where the i've screwed the board and its distorted over the block work. I have the option of removing the ply and getting a plasterer to render the wall and tile directly onto it but feels like " two steps forward and three steps back". Before you all say it....i should have done it right in the first place icon_lol.gif
Thermo - "What is it today with people wanting answers straight away??????????"
Sorry. The minimoto forum i belong to you normally get answer within the hour....not always the one you want though.
Back to top
 Alert Moderators
chappers
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jan 26, 2005 7:55 pm    Post Subject:
Dringer most of the guys on here likely to give you an answer are usually out at work at 4.30pm but will usually help if they can when they log on and later in the evening you are more likely to get a quicker response.
Just be patient I'm sure the job isn't that urgent, but I wouldn't worry too much about dips of that sort of magnitude you shoud be able to take them out with the adhesive
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
Bathroom Floor TIling - plywood 4 1760 Wed Aug 09, 2006 7:29 am
treating plywood for tiling 4 2800 Mon Mar 20, 2006 11:32 pm
Tiling on to plywood 3 1080 Mon Apr 09, 2007 4:50 pm
Tiling over WBP plywood 3 3060 Fri Feb 23, 2007 1:19 pm
Tiling on top of plywood or mdf 2 1500 Wed Oct 20, 2004 5:44 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
