overfilling indesit
22 Jan 2005
i\\\'ve got an indesit WE 16.
it keeps overfilling.the display screen says - H20. SOMEBODY HELP ME ! :mad: :mad:
what does the manual say?
(it may be the pressure chamber or pressure switch, punctured pipe)
the manual says diddley squat ! :rolleyes:
so- do i have to call an engineer ? :confused:
same happen to me on saturday afternoon. if i find a solution i'll let you know
i've got mountains of dirty washing ! :evil:
so, i've got an engineer coming in the morning. :)
i' ll let you know what he says ! :confused:
I had the same problem, I found the pipe going from the pressure switch to the bottom of the drum had rubbed through. With the vibration of the drum the spacer sponges slip down the pipe allowing it to touch the side of the machine and then wears through. I found you can either repair the tube or replace it and tape the sponges in plce, solving the problem.
