| Author |
Message |
lothianhomebuilder
Joined: 03 Nov 2009 Posts: 2 Location: United Kingdom
Posted: Tue Nov 03, 2009 11:42 am |
Can I wire in a new double socket off immersion heater supply to power Fridge freezer? Supply is protected by Wylex MCB rated B16. Immesion heater is seldom used as it is back up should gas c htg fail. |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
Steve
Joined: 15 Apr 2005 Posts: 15753 Location: Yorkshire, United Kingdom Thanked: 211 times
Posted: Tue Nov 03, 2009 11:46 am |
No.
You may only do this if you disconnect the immersion and all its wiring, back to where you want the fridge freezer. |
| Back to top |
lothianhomebuilder
Posted: Tue Nov 03, 2009 1:48 pm |
So its plan B with a spur off existing ring main which involves lifting some rather nice varnished floorboards. Thats life. |
| Back to top |
mfarrow
Joined: 02 Nov 2009 Posts: 751 Location: Warwickshire, United Kingdom Thanked: 72 times
Posted: Tue Nov 03, 2009 8:37 pm |
Why not? Regs don't say don't and the OSG doesn't list its source. Besides which it only says "on its own circuit" which an FCU would accomodate for anyway.
Immersion heaters are used so rarely if you've got C/H, it's a shame not to take advantage of the spare capacity the MCB can provide.
A fridge/freezer has such a small power consumption that as long as you label the socket "Fridge Freezer only" I don't see how/when it'll ever be an issue. |
| Back to top |
londonboy
Joined: 22 Feb 2009 Posts: 1576 Location: London, United Kingdom Thanked: 146 times
Posted: Tue Nov 03, 2009 9:28 pm |
It is listed. Cant quote it but it says something about water heaters over 15litres, also heating elements over 2kw should be on a radial. |
| Back to top |
RF Lighting
Joined: 31 Mar 2006 Posts: 16288 Location: Leeds, United Kingdom Thanked: 738 times
Posted: Tue Nov 03, 2009 9:37 pm |
It is recommended in the OSG, but not actually a regulation in BS7671.
Really really rubbish circuit design for it to supply anything else though. |
| Back to top |
mfarrow
Posted: Tue Nov 03, 2009 9:50 pm |
| RF Lighting wrote: | | Really really rubbish circuit design for it to supply anything else though. |
Unconventional and indiscriminate, but we need to give the lad his options... |
| Back to top |
333rocky333
Joined: 12 Jan 2008 Posts: 3631 Location: Essex, United Kingdom Thanked: 200 times
Posted: Tue Nov 03, 2009 9:52 pm |
just a thought, what if the heater switch was changed to a socket, then it would be two sockets on a radial.
If he ever needs the element he could plug it in.
Is that a really rubbish idea. |
| Back to top |
RF Lighting
Posted: Tue Nov 03, 2009 9:53 pm |
Yep |
| Back to top |
