Zanussi DE4744 Dishwasher Problem Please Help !!!!!!
25 Jan 2005
The dishwasher drains water out first, then it fills up and then it just stops. Two lights then flash at the same time (the drying light and the finished light) at the same time. This happens 90% of the time, occasionally it will work fine but seems a bit noisy like a whistling sound. Can anybody help as i have only used this about 70 times over 2 the two years have had it.
Richard.
Sounds like it siphoning out, is your waste pipe to low ?
No the wastepipe is higher than the machine by about 2".
The machine seems to only empty first when the last wash wasn't successful.
can you get me the prod number off the machine.
will check on this for you.
can send you a service manualpdf file if you like
________________________________________-
Moderator
please see 7
I have found these numbers on the side of the door:
PNC 911788006/02
S.N 24480046
Type 911N71-BF
Hope this is what you wanted.
ok you will have to email me to get link...
will not let me help u..
or try this
applianceforum.co.uk
/modules.php?name=
Downloads&d_op=
viewdownload&cid=11
No still doesn't work could you forward it to my e-mail
Thanks for your help.
Moderator
email address removed these can be shown in your profile
you need to put ur email in your profile..
Moderator
