baffled4now
Joined: 25 Jan 2005 Posts: 2 Location: United Kingdom Thanked: 0 times
Thermo
Joined: 21 Oct 2004 Posts: 8456 Location: Sussex, United Kingdom Thanked: 31 times
Posted: Wed Jan 26, 2005 8:21 pm Post Subject: |
is the room under the steps ie like a cupboard and not heated and seperate from the house? __________________ have grace to accept what cant be changed, strength to change what can, wisdom to see the difference |
baffled4now
Posted: Thu Feb 03, 2005 5:52 pm Post Subject: |
The room is inside the flat but not heated. It is basically underneath the outside steps leading to the flats above. As it isn't heated I am thinking condensation. |
liamconnolly
Joined: 27 Jan 2005 Posts: 5 Location: United Kingdom Thanked: 0 times
Posted: Wed Feb 09, 2005 7:21 pm Post Subject: |
Hmm, sorry to hijack your post but i have a similar query.
I have a old sandstone tenement property and have noticed a build up of brown mould at the top of the bathroom wall/ceiling juncture. This is above where the shower is located and i assumed it was mould formed by condensation. an extractor is used.
in the adjoining room there are damp patches that are now showing through. i fear that the property above (bathroom in same place) may be leaking into mine.
basically i would not have excpected this to just appear after 5 mths in the flat and i know that the owners above have just fitted a new shower...
Any thoughts/suggestions?
Thanks |
Thermo
Posted: Wed Feb 09, 2005 7:47 pm Post Subject: |
sounds like there could be a leak above where the tray is not sealed properly. Have a chat with your neighbours. If it was condensation from the shower you wouldnt be getting it in the other room __________________ have grace to accept what cant be changed, strength to change what can, wisdom to see the difference |
