Foam filler spray can
18 Jun 2006
Sussex
Hi Does anyone know of a foam filler spray can that does not have to be used upside down?
My problem is that I need to fill draft gaps and vermin holes under my chalet so it is impossible to hold a spray can upside down, I have tried and its a total waste of time.
I only need a 2 or 3 cans.
Max
Hi
Thanks for the response, but all the cans that I have ever used or seen have to be held upside down. I will check Screwfix out.
Regards
Max
as long as the vermin are dead or you plan on using concrete metal or wood to repair the structure
foam is simmilar in strength to paper rolled up in a ball and pushed in
