fitting a pull switch on shower
6 Apr 2008
Yorkshire
my shower as a shut of switch outside.
can i have a new cable laid with a pull switch inside bathroom?
and does it matter having a 2 switches on same cable.
thanks
Yes.
It's a bit pointless, as both would need to be on for the shower to work.
Why not just get rid of the one outside, or re-use it in the new location in the bathroom?
first, thanks for taking time to reply.
it is easier to leave the switch in , if not , would'nt i have to run a new cable to the shower?
or can i put a juction box were the old switch was?
It depends on where the cables run - you might need a longer one you might not, but your electrician will be able to extend it if necessary.
