Red hot water from Creda shower
12 Nov 2009
Nottingham
Hi, i'm new to this site, and am just after a few answers.
I moved into my new home almost exactly 1 year ago, and the shower has been running fine until yesterday. I don't know how old the shower unit is but it is a Creda Aqua 9.5E. The problem now is that no matter what setting it is on, it just offers boiling hot water, so much so that you cannot stand under it. I have a Glow-Worm Combi boiler, and am not sure whether this will have anything to do with the problem. I'm assuming that the shower's thermostat has gone, but technically savvy i am not. I suppose i just want it confirming more than anything else. If it is the thermostat is it a case of replacing a part, or is it a whole new shower unit required.
Any help will be gratefully received.
Cheers !
The Creda Aqua 9.5E is an instantaneous electric shower. They regulate the temperature by adjusting the water flow rate. if the flow through them is reduced, the temperature goes up.
Check the handset hose isn't kinked or twisted and any service valves in the water supply are fully open, including the mains stopcock. Clean and de-scale the shower head. Look for any filters in the water supply connection that may need cleaning.
Thanks for your reply Tickly.
I unplugged the shower head, and cable from each other and the main unit, and touch wood, it seemed to work. Only used it once last night, but it seems to have done the trick.
Much appreciated.
