I was hoping someone might be able to advise on a problem we are having with our boiler.
We have an Ideal mini HE boiler fitted a couple of months ago, which was meant o be an end to our heating problems, but no such luck!
Hot water is fine and sometimes the heating works, but often when we switch the heating on the boiler makes all the right sounds like it is firing up, but it doesn’t appear to ignite, (I don’t see a flame through the viewing hole, which I do see if I turn a hot tap on). Sometimes it does come on, but then it switches itself off again after about 10 seconds.
We have radiator thermostats, which I have made sure are all open, and we have a control box on the wall next to the boiler which has on/once/twice/off – and this is ‘on’.
We have had the plumber that fitted the boiler come back, he couldn’t find the fault (because of course it was fine when he was here), but I think he replaced the thermostat in case it was that – but later we had the same problems of no heat in the radiators at all, so we had an engineer come from Ideal. He wasn’t sure what was wrong, but he tightened a loose washer on the gas outlet in case it was that (as he said the flame was starting high above the outlet, which may have made the safety sensor switch the boiler off??)
That seemed ok for a day or so, but we’re still without heat coming out our radiators on a reliable basis. This is very confusing as it does sometimes work fine…but other times I’m sat in the cold with a noisy boiler, but no heat! Any advise would be great, as it seems no-one we’ve called out knows what is wrong…
thank you
thank you
