I have a 7mm rawl plug which is loose. I drilled a 7mm hole in conrete block, but the screw just causes the plug to spin. I have removed the wall plug and cleaned the hole, but the hole is now slightly bigger.
I still need to put a fixing in the same place, as all the other fixings are fitted. What is the best method of repair, if I want to fit another rawl plug in the same place?
