Installed laminate floor over parquet floor - huge mistake!
27 Jan 2005
We bought this used condo which currently has parquet floor on living and dining room.
I guess we have made a huge mistake by letting the contractor convinced us that there was no need to remove the parquet floor. Since laminate floor is already installed on living and dining room now (on top of the parquet floor), there is no way to fix it now
On the other hand, I guess it's my fault that we didn't do enough research ...
Must be me, but I don't get your problem?
If you mean it's a waist of 'investment' to cover up your wonderful parquet floor, then yes, I fully agree with you ;)
:) That's not what I meant. I regret that I didn't remove the parquet floor :(
I heard it is bad to install laminate floor directly on top of parquet floor:
"Concrete will always have moisture vapor emissions. Trap those vapors under the new laminate floor and the parquet will buckle off the concrete, under the new laminate."
I'm sure you would have been much happier with the parquet floor ;) Much nicer, richer and durable.
But that's me: into Natural Wooden flooring ;)
Can't you remove the Laminate flooring and start enjoying your real floor
Ultimately, I would want laminate floor only :)
But, it just does not make sense to remove the laminate floor now ... I guess we need to live with it ...
ah a problem solved all by itself. Im with you woodyoulike natural wood, cant beat it anywhere
Be careful!
I installed laminate flooring over an old parquet wood floor and it's now all buckling up and I'm going to have to replace the whole lot.
Would have kept the old floor, but had been painted, and was only in about a 3rd of the room for some reason!
If there was a dpm or combi underlay used on top of the existing floor it can cause it to "sweat" which will make it expand and swell and can result in causing the laminate to lift.
If the concrete has a dpm under it then I can't see the problem.
I concur with the others - who in their right mind would want laminate floor over natural wood?
As trim has already asked. Is it a dpm underlay. You can lay laminate over a real wood floor. Just a couple of things you do different. And joe if the floor didn't have a dpm of some kind don't you think the wooden floor already installed would have problems with it?
Not sure if I was clear enough - I ment that you don't put any form of dpm on top of the parquet. As matty says there must already be a form of dpm under the parquet or it would have done a good impression of a mexican wave (good practice for sking on moguls but thats about it).
Hi trim67
No, you don't put a DPM on an underfloor that is made of wood (like your parquet or existing floorboards) or sheet materials (like chipboard, plywood etc).
