mira sprint shower
17 Nov 2009
Aberdeen
My mira sprint shower was made in 1999 and has now stopped working correctly. the shower works when on the cold setting, but when turning the dial to low or high heat the low pressure light appears and only cold water appears in what appears to be low pressure.
Mira advised that i check the filter but I could not open the top blanking cap so instead i opened the bottom, then put the shower back together again and the first time of turning on all settings the shower worked perfectly, but the next time i went to use the shower i experienced the same problems as before. can anyone provide advise?
