DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Stopcock jammed closed
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
RobertH
from France
PostPosted: Tue Nov 17, 2009 12:23 pm Reply with quote
Hi
I have a 3/4" stopcock which operates with a lever which you turn through a quarter turn to close it - I don't know if you have this type in the UK, I am in France. I closed the stopcock to do some work on the pipes and now I have come to turn the water back on again, the lever will not move. It has only been closed for 24 hours so cannot possibly be jammed with limescale or corrosion. Any suggestions please?
Back to top
 Alert Moderators
bertrum09
from United Kingdom
PostPosted: Tue Nov 17, 2009 6:42 pm Reply with quote
either loosen the nut on the valve or use some oil or a type of lubricant to try and loosen it.
Back to top
 Alert Moderators
bellairaphon
from United Kingdom
Thanked: 43 times
PostPosted: Tue Nov 17, 2009 8:34 pm Reply with quote
can you realease the top connection and look into the valve? sometimes the ballvalve inside can shear away from the handle and jam it shut. do you have an outside main isolation valve for your house?
Nathan
Back to top
 Alert Moderators
RobertH
from France
PostPosted: Wed Nov 18, 2009 4:14 pm Reply with quote
Tried putting penetrating oil down the spindle, made no difference. Removed pipe from outlet but could see nothing wrong inside. I have now replaced the stopcock, this was inside the house and I was able to shut off the water outside the house.
Thanks for your comments.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Jammed leaking Stopcock 11 360 Tue Jun 15, 2010 6:26 pm
Jammed stopcock? 3 60 Thu Dec 15, 2011 4:54 pm
Turning a jammed gate Valve 5 620 Mon Oct 12, 2009 2:34 pm
Jammed External Water Tap 20 1340 Sun Aug 09, 2009 8:08 pm
boiler timer is jammed 2 280 Wed Nov 11, 2009 1:06 am
DIYnot
