DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Flexible paint for covering Hairline Cracks in Plaster
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
Author Message
wytco0
from United Kingdom
PostPosted: Fri Jan 28, 2005 8:56 am Reply with quote
I have done several searches but I cant find an answer to this question however that might be because what I am after does not exist !
My 1960's town house has plastered walls which were wallpapered for many years, about 5 years ago we stripped all the wallpaper back to plaster and smoothed it as much as possible. It was then sealed and emulsioned.
There are a number of hairline cracks in the plaster, I have painted them over a couple of times but the reopen, I suspect as a result of expansion/contraction throughout the year.
I would like to find a paint that has enough bulk to fill these cracks and which is also flexible enough to ensure that they don't open up again, does such a product exist?
I know several emulsions claim to do this but the ones I have tried do not work !!
I really do not want to use lining paper as I don't like it at all.
Thanks.
Back to top
 Alert Moderators
david and julie
from United Kingdom
PostPosted: Fri Jan 28, 2005 9:09 am Reply with quote
I've used a polycell product called crack free ceilings with good results, obviously I used it on the ceiling but it sounds similar to what you describe.
Try a product search on their site and see what you think.They also do a product for levelling and smoothing plaster, but I can't remember the name.
http://www.polycell.co.uk/webapp/wcs/stores/POLUK/Home/Jsp/Home.jsp
Last edited by david and julie on Fri Jan 28, 2005 9:14 am, edited 1 time in total
Back to top
 Alert Moderators
Thermo
from United Kingdom
Thanked: 148 times
PostPosted: Fri Jan 28, 2005 3:30 pm Reply with quote
see my reply on the thread ceiling cracks about four topics down from this one.
Filling it with paint will take a lot of time and is a waste of time as it will only open up again. you need to use a decorators caulking
Thermo
Back to top
 Alert Moderators
david and julie
from United Kingdom
PostPosted: Fri Jan 28, 2005 9:23 pm Reply with quote
Decorators caulk usually yes, but wytco0 said he wants his wall as smooth as possible, he can't sand caulk down and it often sinks a small ammount. Thats why I have suggested he looks at those products.
I would fill the cracks with caulk as Thermo said to reduce the size and then try one of the flexible paints.
btw, those flexible polycell paints can be overpainted but you may have to wait a while. Make sure you read the instructions about waiting times.
I did this on a ceiling 4 or 5 years back and its still OK.
Back to top
 Alert Moderators
Thermo
from United Kingdom
Thanked: 148 times
PostPosted: Sat Jan 29, 2005 8:46 am Reply with quote
if you apply it and then go back over with a smooth damp sponge, with a little practice you can get it virtually invisible.
Back to top
 Alert Moderators
chappers
from United Kingdom
Thanked: 30 times
PostPosted: Sat Jan 29, 2005 11:08 am Reply with quote
use a very fine filler such as semin joint taping filler its also really easy to sand off.
Theres a tip for you don't use polyfiller or the likes, use drylinning jointing filler. I always use semin CE78 rapide it can be sanded back after about an hour or so rather than having to wait overnight, it is probably finer than any other filler available and sand back really easily.
Not really suitable for exterior though.
Back to top
 Alert Moderators
matpol
from United Kingdom
PostPosted: Mon Feb 07, 2005 1:55 pm Reply with quote
great for filling small cracks - easy to sand and better than paint!
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 209 times
PostPosted: Mon Feb 07, 2005 3:28 pm Reply with quote
I have been using Polycell for fine cracks, then rubbing down, then emulsioned.
I finished painting 2 weeks ago so far so good no cracks.
The cracks I filled were in a new plastered wall & big ugly cracks (not many pretty ones about).
Back to top
 Alert Moderators
cazmick
from United Kingdom
PostPosted: Fri Feb 25, 2005 7:58 am Reply with quote
Don't know if this will help you guys. However i repair a lot of GRP damaged items and when the GRP gets damaged it results in crazing= lots of minute cracks everywhere. They can't be filled successfully until the cracks are raked out and made bigger, thus allowing a good thick layer of filler to be applied. Once done they do not re-appear.
Back to top
 Alert Moderators
Bigfoott
from United Kingdom
PostPosted: Thu Jan 31, 2008 1:11 pm Reply with quote
I went with Dulux Flexible matt paint for my ceiling, tried filling the cracks with fine filler but came back. The flexible paint has done the trick, but to be honest it looks a bit plastic, can I paint over the flexible paint with just normal matt now ?
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
durable and flexible wood paint 2 80 Tue Jul 24, 2012 1:22 pm
Flexible Paint on Walls 2 600 Mon Oct 12, 2009 10:12 am
Rubber/flexible coving? 3 120 Thu Mar 07, 2013 5:18 pm
Flexible gap Polyfilla in interior walls? 8 1420 Sun Aug 30, 2009 4:18 pm
Flexible foam sanding pads on architrave? 5 280 Wed Feb 16, 2011 10:41 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
