Saunier Duval thernaclassic f24e
20 Nov 2009
Kent
Hot water fine from boiler to all taps , but central heating not working , is fireing up for about 30sec then going out ,then firing up again after about 3-4min and so on , first rad hot , 2nd warm but cold else where , pump working can hear it and feel it pushing the water in the pipes in the hall coming from upstais. On advice have changed PCB and water flow sensor, but still the same .Any ideas All help and advice grateful
Its an unusual fault for one of these, but I would suspect the diverter valve is stuck in hw mode. Could be the head or the body or both. You can take the head off to check its movement, and check the pin for free movement, should push in and spring back.
Is there a return filter in the CH ?
On their later condensing boiler there is a rather odd filter just to the right of the pump.
Tony
