Hi all, Sorry if this already appears on the forum, but I am unable to see the posting which I was sure I made @ 16:15 today and have not seen any responses so I guess that I failed to post it correctly.
OK, my first posting herein although I have often turned to this excellent forum for information and help.
My problem: I have just installed a thermostatic mixer bath tap/shower unit for the outlaws which is working “intermittently”. It was a simple job - apart from the usual issues of tight space to get a spanner to the tap retaining nuts. - I had to install the unit since the old folk were having problems getting the fine adjustment required to obtain the correct temperature on the existing non thermostatically controlled unit. Once I turned the cold & hot water stopcocks back on the thermostatic control did not appear to let the hot water through the mixer. To check there was hot water in the system I turned the sink hot tap on. Soon after the mixer tap delivered the hot as required as set on the thermostat. The tap (bath filler) & shower feed subsequently worked fine on Friday. I had a call on Saturday saying that hot water was not being delivered, only cold. Again I turned the sink hot tap on and again the hot water started to flow ok as it did for several further attempts shortly afterward. I made a further check today and again no hot flow. The basin trick did not seem to work this time so I opened the kitchen sink tap & the hot again flows fine.
My thoughts – wrong or right - are that there is either an air lock or water lock that reaffirms itself after a period of time. Or it could be the obscure way the water pipes are configured in the house.
Does anyone have any suggestions on how to resolve this issue?
Thanks.
Thanks.
