We had a shower unit installed two months ago.
The double pole ceiling pull switch malfunctioned and I obtained an exact replacement and fitted it. It is working okay.
However on reflection something is worrying me, - there was only one earth wire - which I assume is from the consumer unit.
Should there not be an earth wire from the S.U. which should connect into the same earth terminal on the switch?
The shower circuit is connected via an RCD.
