DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Toilet slow to fill up cistern after flushing.
Goto page Previous  1, 2, 3
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
TonyW2
from United Kingdom
Thanked: 47 times
PostPosted: Fri Apr 13, 2012 2:02 pm Reply with quote
Should turn by hand grip.
Use a rag on it?
Anything in the kitchen drawer for opening jam jars?
A big wrench--with care on the plastic?
Back to top
 Alert Moderators
TonyW2
from United Kingdom
Thanked: 47 times
PostPosted: Fri Apr 13, 2012 2:03 pm Reply with quote
Delete double posting
Back to top
 Alert Moderators
saleemster
from United Kingdom
PostPosted: Fri Apr 13, 2012 2:48 pm Reply with quote
Hi there. I have the same issue on two toilets and have ordered replacement diaphragms from Steve at toiletparts.co.uk.
Can anyone advise how I should approach this? Where is the big plastic nut?
Thanks!
Back to top
 Alert Moderators
TonyW2
from United Kingdom
Thanked: 47 times
PostPosted: Fri Apr 13, 2012 5:15 pm Reply with quote
The thing that looks like a biscuit cutter.
The big knurled ring,
Back to top
 Alert Moderators
wendrick
from United Kingdom
PostPosted: Tue Apr 17, 2012 10:44 am Reply with quote
Well - I finally capitulated over the week-end - I couldn't get that nut off to replace the washer so I called in a plumber who also couldn't get the nut off despite all his expert tools! So I ordered the whole inlet thing off the Ideal Standard web-site so hopefully I can fit that OK.
But I have another problem!! I live in a three story town house with a bedroom on the ground floor and an en-suite shower and toilet room. When we flush the toilet the rubbish clears but the water is relatively slow to empty down to its normal level. There doesn't appear to be any blockages either in the toilet, the u-bend or in the outlet soil pipe. I wonder what the problem is.
Thanks to everyone who helped me on my first issue you were very kind.
Back to top
 Alert Moderators
FUNKYDADDIO
from United Kingdom
PostPosted: Thu May 10, 2012 9:55 pm Reply with quote
Hi Guys, what a brilliant forum. I have this cistern mechanism. I have put the new diaphragm in and it is now filling up inconsistently. Sometimes the float stops it overfilling and other times it flows over down the overflow into the bowl. Other times if I flush fully and drain the tank it just runs into bowl (stays less than an inch full) and doesn`t fill tank at all, any ideas folks?? Many thanks.. icon_smile.gif
Back to top
 Alert Moderators
beaudave
from United States of America
PostPosted: Wed May 30, 2012 3:19 pm Reply with quote
Hi guys. I recently had to replace the supply valve in one of my upstairs bathrooms. I also replaced the tank guts and everything was fine for about a week. Then the tank starting filling really slowly, which was why I replaced the guts in the first place. If I turn the valve off and back on, the tank fills faster, but only for the one flush, then back to slow. Now my other upstairs toilet is filling slowly, and nothing's been worked on it. Same thing, turn the valve off\on fills fast for one flush, then back to slow. I was wondering if there's an air bubble or something in the line? Or could it be something else further down the piping? Any help greatly appreciated.
Back to top
 Alert Moderators
kevroberts66
from United Kingdom
PostPosted: Sun Apr 28, 2013 2:14 pm Reply with quote
Hi Brilliant advice, however i have swapped the diaphragm washer and it still takes 15 mins to fill the cistern. where the nut/lever is its like a fine spray coming out?
Any ideas greatly appreciated . thank you
Kev
Back to top
 Alert Moderators
Charnwood
from United Kingdom
Thanked: 334 times
PostPosted: Sun Apr 28, 2013 3:28 pm Reply with quote
What valve have you got?
Picture would help.
Back to top
 Alert Moderators
kevroberts66
from United Kingdom
PostPosted: Sun Apr 28, 2013 5:55 pm Reply with quote
This is a pic of the valve thats causing me problems
[img]
[/img]
Back to top
 Alert Moderators
stevecanterbury
from United Kingdom
PostPosted: Mon Apr 29, 2013 4:37 pm Reply with quote
kevroberts66 wrote:
...where the nut/lever is its like a fine spray coming out?
Kev
I have exactly the same problem, on the same cistern (that seemed to start around the same time you posted yesterday - spooky!!) - would appreciate any possible solutions too; I haven't tried replacing the washer yet as this didn't seem to work for Kev - but will give it a go if people think it's worth the trip to B&Q.
Thanks,
Steve
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 3 of 3
Jump to:
Toilet cistern is slow to fill 3 80 Sat Apr 13, 2013 9:49 am
Cistern slow to fill 4 220 Tue Nov 23, 2010 11:56 pm
Cistern very slow to fill. 11 6120 Tue Jan 17, 2006 12:11 pm
Toilet Flushing after Fill 4 680 Wed Nov 30, 2005 6:24 pm
Torbeck valve slow fill 7 440 Thu Jul 08, 2010 1:12 pm
DIYnot
