Velux flashing kit?
13 Sep 2009
Lancashire
Which flashing kit is best suited for rosemary clay tiles. I've been sold the EDZ type (up to 45mm). Is this ok or ideally should it be EDP (up to 15mm). The rosemarys are old and bowed with age so not sure if this makes a difference
edp is specifically for plain tiles.(Rosemarys etc) Edz can also be used with plain tiles and also interlocking tiles.. Edz is quicker
The EDP flashing would be best especially if you have a few trees around as the tiles are soakered rather than leaving a side gutter for the leaves and crap to fill up with. also you don't have the later issue of the foam disintigrating
