BAXI COMBI 105E...... HOT WATER PROBLEM (DIAPHRAGM)
27 Nov 2009
Lancashire
can any one tell if its safe to say the diaphragm needs changing if the plunger is not coming out to operate the switch. I cleaned it all and put back together but still plunger not operating. If i change the Dhw pressure valve will this sort it or could it be other problems. :(
Done one today funnily enough mate.
Change the full divertor valve behind the Diaphgram as they are funny buggers on this boiler.
They have a pin on them that pushes the Diaphgram pin but when its not working its hard as hell (I find ) to repair and is more cost efficient to replace.
However its quite a fiddly job.
Cheers for your replies guys.....Will i need to drain the system to change the valve behind or do you mean the valve which holds the diaphgram in.
