water tank level indicator
Stick two elbows unto yer tank and fit some clear plastic between.
Simples.
then maybe google chemical industry supplies :idea: . Or rob a steam museum ;)
Try Dean & Wood. They might not stock it but will certainly be able to obtain what you need plus it will be specced for refrigeration applications.
Piece of aluminium plate with a groove filed along it's length, and a piece of perspex stuck on top? Seal ends of groove with a dab of LSX?
Assuming the gauge is connected to the tank by hollow screws, filing a flat on a plain (stainless) screw would probably suffice. Fibre washers on the screws, and you have a gauge.
