DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Kitchen drawer front removal
Post new topic   Reply to topic    DIYnot.com Forum Index > Wood / Woodwork / Carpentry
Author Message
davphi338
from United Kingdom
PostPosted: Sat Nov 28, 2009 2:54 pm Reply with quote
Not sure this the correct section but I suspect carpenters will have fitted a few kitchens in their time.
My problem is the drawer front fron has come away from the actual drawer unit. It is a modern type unit with soft close runners. The drawer front is held on with a brackets that are screwed from the back, these brackets then go into the metal side of the drawer.
I have removed the plastic strip covering the adjustments for the drawers and I can see the bracket and that there is a screw in the middle of it but turning this doesn't seem to release the bracket.
How can I remove this bracket to enable me to screw it onto the back of the drawer front and then re-insert back into the drawer side.
I'm sure this is a simple process when you know how but I don't want to force anything and break the drawer.
Thanks for any advice
Back to top
 Alert Moderators
joinerjohn
from United Kingdom
Thanked: 198 times
PostPosted: Sat Nov 28, 2009 4:11 pm Reply with quote
The plastic bracket should pull straight out from the drawer. Try using a pair of pliers. The screw you can see in the drawer is used to adjust the drawer front, either moves the front up and down or sideways.
Back to top
 Alert Moderators
Jasonb
from United Kingdom
Thanked: 92 times
PostPosted: Sat Nov 28, 2009 4:50 pm Reply with quote
The screw you are turning is the height adjuster
About 30mm nearer to the front of the draw is a part covered metal plate with a "+" to take a phillips screwdriver. as you put the screwdriver into the + the part covering it will move, then turn the screw appro 45 degrees and this will release the bracket.
To replace the draw just push it back in and it will snap intoo place.
You DO NOT need pliers
Jason
Edit have a look at page 38 of this pdf
http://www.blum.com/pdf/katalog/ka090_en/04/KA090-KP-004_buk.pdf
Back to top
 Alert Moderators
joinerjohn
from United Kingdom
Thanked: 198 times
PostPosted: Sat Nov 28, 2009 5:05 pm Reply with quote
Jason, the OP did say that the drawer front has came off the bracket. He's asking how to get the bracket out of the drawer. icon_wink.gif
Back to top
 Alert Moderators
Jasonb
from United Kingdom
Thanked: 92 times
PostPosted: Sat Nov 28, 2009 6:29 pm Reply with quote
Its the same way whether the bracket is fixed to the draw or not, a 1/8" turn will have it just pop out, there is quite a strong spring. If he did as you says and tries pulling it out with pliers he will either damage the diecast (they are not plastic) bracket or b*****er the draw side.
Jason
Back to top
 Alert Moderators
joinerjohn
from United Kingdom
Thanked: 198 times
PostPosted: Sat Nov 28, 2009 7:12 pm Reply with quote
The OP does say that the brackets are plastic. I'm assuming they are not the same as the Blum ones. Perhaps a bit like the Cook & Lewis kitchens from a well known shed. If it is this type then all he has to do is pull out the plastic bracket as its held in with the cover clip.
Back to top
 Alert Moderators
davphi338
from United Kingdom
PostPosted: Sat Nov 28, 2009 7:22 pm Reply with quote
Thanks for all the replies,
jasonb you were right there was a partially hidden + screw that when quarter turned popped the bracket out. All sorted now.
Back to top
 Alert Moderators
Jasonb
from United Kingdom
Thanked: 92 times
PostPosted: Sat Nov 28, 2009 7:56 pm Reply with quote
Told you so icon_wink.gif , Joiner, the OP said the covers were plastic.
Jason
Back to top
 Alert Moderators
joinerjohn
from United Kingdom
Thanked: 198 times
PostPosted: Sat Nov 28, 2009 10:25 pm Reply with quote
Humble apologies Jason. I stand corrected (must learn to read one day) icon_redface.gif
Back to top
 Alert Moderators
antiqueone
from United Kingdom
PostPosted: Wed Sep 28, 2011 6:27 pm Reply with quote
I have had a kitchen with blum drawers for about six years. The drawers are terrible, they can't be loaded very much. But now I have the problem of finding out how to refit a front that has fallen off. Can anyone tell me exactly where the cross is that I have to turn to get the brackets out?
Back to top
 Alert Moderators
antiqueone
from United Kingdom
PostPosted: Wed Sep 28, 2011 7:06 pm Reply with quote
At long last I have found the cross, it is about 20mm behind the big screw and above it in a rectangular hole. Give me wooden drawers any day. The glide and soft shut only works with empty drawers and doesn't give any advantage at all. Why ever make drawers this complicated?
Back to top
 Alert Moderators
Jasonb
from United Kingdom
Thanked: 92 times
PostPosted: Wed Sep 28, 2011 7:13 pm Reply with quote
You can buy the blum runners in different weight capacities. I use the 30kg ones for smaller draws and the 50kg for pan draws and have not had any problems with any of the kitchens I have made.
J
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Wood / Woodwork / Carpentry All times are GMT
Page 1 of 1
Jump to:
Removal of kitchen Base Unit 5 600 Tue Mar 14, 2006 7:35 pm
PANEL PIN REMOVAL FROM ORIGINAL DOOR 5 580 Tue Feb 23, 2010 4:33 pm
Removal of Wood Glue 3 620 Thu Apr 03, 2008 4:31 pm
Wood post removal 4 160 Mon Sep 22, 2014 5:58 am
Removal of French Door fixed panels 2 40 Sat Oct 08, 2011 11:17 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
