DIYnot
Local | Network
   DIYnot > Forums
Local | Network
boiler not lighting
This topic originated from the How to page called Problems associated with noises from the central heating system
Click here to return to the page called Problems associated with noises from the central heating system.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Lisa5
from United Kingdom
PostPosted: Mon Jan 31, 2005 10:45 am Reply with quote
I have no water or heating due to the pilot not lighting in the boiler. The reset doesn't do the job, we have no flame failure light but do have power on light lit. It's a performa 24 potterton, somebody please help freezing with 5 young children.
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1097 times
PostPosted: Mon Jan 31, 2005 11:31 am Reply with quote
It doesn't have a permanent pilot, it lights itself when needed.
Check the pressure is about 1 bar. If not, look up "filling loop".
Back to top
 Alert Moderators
Lisa5
from United Kingdom
PostPosted: Mon Jan 31, 2005 11:42 am Reply with quote
We have checked the pressure and that is at 1 bar, it was low we did put it back up to 1 yesterday we thought that was the problem at first. I had a look at filling loop and the picture for it is a part that we noticed a bit of water dripping from could this need replacing?
Back to top
 Alert Moderators
paulgorry
from United Kingdom
PostPosted: Mon Feb 14, 2005 8:28 am Reply with quote
Hi Lisa, I seem to have the same problem. I switched the Performa 24 off at the wall (whilst having a radiator bled) swithed it back on and there is no hot water or central heating. Did you get the problem sorted out? or do I need a plumber? Many thanks...Paul G
Back to top
 Alert Moderators
Lisa5
from United Kingdom
PostPosted: Mon Feb 14, 2005 9:03 am Reply with quote
yes it was due too the boiler overheating .it has a shut down switch internal that needs to be reset.pull down the grey panel find pipe on left hand side with 2 wires coming out in a v shape.between the two wires is a little white switch use screwdriver to prod it back in and this will reset the boiler and it should work best of luck.
Back to top
 Alert Moderators
paulgorry
from United Kingdom
PostPosted: Mon Feb 14, 2005 9:13 am Reply with quote
Many thanks Lisa. I'll try it when I get home (fingers crossed!). Many thanks for the speedy reply!!! Paul...
Back to top
 Alert Moderators
M.J.B.7.0
from United Kingdom
PostPosted: Fri Jun 22, 2007 9:52 am Reply with quote
just joined forum because i had same problem and it works!! engineer quoted me 75 to come out just to look. Thank you for saving me
Back to top
 Alert Moderators
gasandoilman
from United Kingdom
Thanked: 5 times
PostPosted: Fri Jun 22, 2007 12:05 pm Reply with quote
Am i too cheap or was he ripping you off??
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 787 times
PostPosted: Fri Jun 22, 2007 4:36 pm Reply with quote
I would be 50 + VAT
Back to top
 Alert Moderators
Si_W
from United Kingdom
PostPosted: Wed Jul 25, 2007 11:53 pm Reply with quote
Searched the net with the problem, great solution.
Thank you very much.
Back to top
 Alert Moderators
vickynreg
from United Kingdom
PostPosted: Fri Sep 12, 2008 9:36 pm Reply with quote
Hi can anyone help me,my husband turned the water off yesterday to fix a leak in a pipe,when he turned it back on,we found we had no heating or hot water,we have tried everything but still we are freezing cold,any suggestions,oh its a back boiler.many thanks. icon_mad.gif
Back to top
 Alert Moderators
Corgigrouch
from United Kingdom
Thanked: 364 times
PostPosted: Fri Sep 12, 2008 10:14 pm Reply with quote
Is the pilot still on, have you tried to relight it. What model boiler do you have, later BBUs have auto ignition does it try to light itself when calling for heat?
Back to top
 Alert Moderators
vickynreg
from United Kingdom
PostPosted: Fri Sep 12, 2008 10:17 pm Reply with quote
Yes the pilot light is lit,i now this may sound funny but normally when i light it,it makes a whoosh sound,and there was nothing,and no it never try's to light itself.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 9 times
PostPosted: Sat Sep 13, 2008 7:16 pm Reply with quote
Is this topic now just a dumping ground for all heating problems?
Back to top
 Alert Moderators
obmcfc
from United Kingdom
PostPosted: Thu Jun 04, 2009 1:12 pm Reply with quote
Thanks Lisa, this worked on mine and after 3 cold baths had hot one icon_biggrin.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
My boiler isn't lighting help! 5 200 Fri Oct 02, 2009 10:50 am
Boiler lighting itself intermittently 7 800 Wed Sep 19, 2007 1:30 pm
Heating broken - Ideal Classic boiler not lighting 4 11380 Sat Oct 16, 2010 2:38 pm
my glowworm boiler ultimate 50ff not lighting? 4 2240 Sat Nov 29, 2008 1:01 pm
boiler not lighting 2 20 Fri Dec 02, 2011 7:28 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
