DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Electric shower isolation switch?
Goto page 1, 2  Next
Author Message
r896neo
from United Kingdom
Thanked: 536 times
PostPosted: Tue Dec 01, 2009 11:57 am Reply with quote
I am upgrading to a 10mm cable and changing the pullcord for a switch outside the door for a new electric shower. I am getting someone in to do the connections at switch and CU but as its a small job i want to have everything he needs here ready.
I am running the cable from CU cupboard to the new proposed switch and fitting a dry-lining box into the wall outside the door for it but can i site the box at the level of existing switchs which is 145cm from finished floor or does it need to be lower?
any other preparations advice welcome, i.e. will a standard dryling box be deep enough for this or would a deep one be better?
Back to top
 Alert Moderators
bongos
from United Kingdom
Thanked: 78 times
PostPosted: Tue Dec 01, 2009 12:16 pm Reply with quote
When you say existing switch - do you mean light switch - ie the new shower isolator is going to be next to the light switch?
A deeper drylining box would definitely be better. Have you ever tried to terminate 10mm˛ in a tiny box. icon_lol.gif
Remember this is all notifiable work so your electrician will have to able to inspect the entire cable route to be able sign it off (i'm assuming you have agreed this with them in advance?)
Back to top
 Alert Moderators
r896neo
from United Kingdom
Thanked: 536 times
PostPosted: Tue Dec 01, 2009 4:10 pm Reply with quote
no, the light will be switched by an existing pull cord in the bathroom but i want to create a new isolation switch outside the door, the existing light switches i was refering to are elsewhere on the landing so was hoping to match them.
Back to top
 Alert Moderators
mikhailfaradayski
from United Kingdom
Thanked: 86 times
PostPosted: Tue Dec 01, 2009 5:27 pm Reply with quote
Ditto the bit about notifiable work - please consult your Electrician before doing anything.
In general, theres nothing to say it can't be done that way but consider the downside-
If you have kids/guests etc, whats to stop them accidentally switching off the power to the shower when someone is using it?
I can imagine some teenagers would find it pant-wettingly funny to knock it off whilst sister/brother has soap in their eyes.
Whats wrong with a pull cord isolator next to the bathroom light switch?
Back to top
 Alert Moderators
r896neo
from United Kingdom
Thanked: 536 times
PostPosted: Tue Dec 01, 2009 9:58 pm Reply with quote
The shower empties into a bath and the bathroom is so small that there is nowhere sensible i can site the pull cord that you can not reach whilst using the shower.
As for the routing it is only 10m of cable under the suspended floor in the ground floor and then surface mounted up a wall and into the stud where it terminates so its all easy for him to check and get at if necessary
Any ideas on the height of the box? As said I'd prefer it to match the others nearby at 1450mm or do i need to put it at 1200
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1895 times
PostPosted: Wed Dec 02, 2009 8:40 am Reply with quote
r896neo
Thanked: 6 times
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1895 times
PostPosted: Wed Dec 02, 2009 8:42 am Reply with quote
So?
You can have it at whatever height you like.
Back to top
 Alert Moderators
holmslaw
from Vanuatu
Thanked: 400 times
PostPosted: Wed Dec 02, 2009 8:47 am Reply with quote
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1895 times
PostPosted: Wed Dec 02, 2009 8:51 am Reply with quote
What's the purpose of the switch?
Back to top
 Alert Moderators
holmslaw
from Vanuatu
Thanked: 400 times
PostPosted: Wed Dec 02, 2009 12:20 pm Reply with quote
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 891 times
PostPosted: Wed Dec 02, 2009 12:37 pm Reply with quote
To isolate the shower for maintainance with the isolator in full view of the technician while he or she is working so it cannot be turned on by another person without the technician being aware of it before receiving a potential lethal electric shock.
Or
To rapidly turn off power to the shower when the shower unit is malfunctioning and it is unsafe to approach due to scalding water, melting plastic or sizzling electrical activity on the surrounding wall. It does help in this situation to have the switch inside the room and thus avoid the appearance of a wet and shaken naked body on the landing outside the bathroom. This could cause embarrassment.
Back to top
 Alert Moderators
GaryMo
from United Kingdom
Thanked: 165 times
PostPosted: Wed Dec 02, 2009 1:20 pm Reply with quote
I cant see how having a shower isolation switch on a landing can be a departure from BS7671 unless the manufacturer specifically states a required distance and that its located in the same room as the shower.
The isolation for maintenance reason given above doesnt stand as the protective device for that circuit could be locked off or pulled in the same way it would be when working on a socket or luminaire.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1895 times
holmslaw wrote:
"537.2.1.2 Suitable means shall be provided to prevent any equipment from being inadvertantly or unintentionally energised."
Why is a switch just outside the doorway unsuitable?
Why can't the MCB for the shower circuit be used for that?
So it's an emergency switch?
Back to top
 Alert Moderators
holmslaw
from Vanuatu
Thanked: 400 times
PostPosted: Wed Dec 02, 2009 1:46 pm Reply with quote
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1895 times
PostPosted: Wed Dec 02, 2009 1:59 pm Reply with quote
So why can't you have the switch for the shower outside the door and use the MCB to prevent it from being inadvertantly or unintentionally energised?
Back to top
 Alert Moderators
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Electric shower isolation switch? 2 380 Fri Nov 13, 2009 9:44 pm
electric shower local isolation 26 460 Sun Aug 10, 2014 1:29 pm
New electric shower isolation 6 680 Sun Oct 28, 2007 7:31 pm
Shower isolation switch 18 240 Sun Nov 17, 2013 1:45 pm
Shower Isolation Switch 15 440 Mon Mar 26, 2012 10:30 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
