DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Ford Transit van struggling to fire up in a morning!
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance
Author Message
tommyl18
from United Kingdom
Thanked: 29 times
PostPosted: Tue Dec 01, 2009 2:12 pm Reply with quote
Hi everyone any ideas whats causing my van to struggle to start on these cold mornings turning over for ages before it attempts to fire up. once it starts it then runs for about 5 to 10 seconds then cuts out it starts again straight away once you turn it over again but then keeps cutting out for about a minute then it runs fine do you think it could be the glow plugs?
Back to top
 Alert Moderators
tommyl18
from United Kingdom
Thanked: 29 times
PostPosted: Tue Dec 01, 2009 2:14 pm Reply with quote
just to add to the above its a ford transit 1997 long wheel base 2.5 litre i have looked at getting some glow plugs but only seem to see glow plugs on the internet to fit a 2.4 litre ford transit are these the ones im after?
Back to top
 Alert Moderators
^neo^
from United Kingdom
Thanked: 43 times
PostPosted: Tue Dec 01, 2009 8:07 pm Reply with quote
has it got glow plugs??
Anyway, if it runs then dies, it wont be the glow plugs.
Has it had a diesel filter change lately?
Back to top
 Alert Moderators
dpsservices
from United Kingdom
Thanked: 6 times
PostPosted: Tue Dec 01, 2009 9:26 pm Reply with quote
wont have glow plugs mate could need the leak off mod done also could prob do with a service using 5/30 semi oil and fuel filter change also wouldnt harm to check your timing regards david
Back to top
 Alert Moderators
tommyl18
from United Kingdom
Thanked: 29 times
PostPosted: Wed Dec 02, 2009 10:58 am Reply with quote
Its a diesil injection and i dont think its had a fuel filter change for a long time is that what could be causing it? it started fine before the cold weather came
Back to top
 Alert Moderators
dpsservices
from United Kingdom
Thanked: 6 times
PostPosted: Wed Dec 02, 2009 7:08 pm Reply with quote
Back to top
 Alert Moderators
gregers
from United Kingdom
Thanked: 442 times
PostPosted: Wed Dec 02, 2009 8:05 pm Reply with quote
battery??
Back to top
 Alert Moderators
dpsservices
from United Kingdom
Thanked: 6 times
PostPosted: Wed Dec 02, 2009 8:59 pm Reply with quote
possible could be wrong oil could be worth checking to make sure he has the big starter motor fitted as there is 2 versions
Back to top
 Alert Moderators
tommyl18
from United Kingdom
Thanked: 29 times
PostPosted: Wed Dec 02, 2009 10:11 pm Reply with quote
its just had a new battery and alternator fitted a few weeks back turns over fine not slow at all it was taking ages to fire up before they were fitted so the problem must be something else
Back to top
 Alert Moderators
davieboy
from United Kingdom
Thanked: 12 times
PostPosted: Thu Dec 03, 2009 12:28 am Reply with quote
could be the fuel lift pump dying. or a leak in the diesel pipework somewhere drawing air.
lift pump cheap as chips and 10 mins to change. it sits on passenger side of engine, bolted to block. might not be this though, but if you can get one cheap enough worth a try. (my local factor does them for under a tenner)
you dont have glow plugs by the way, so it cant be them.
Back to top
 Alert Moderators
tommyl18
from United Kingdom
Thanked: 29 times
PostPosted: Thu Dec 03, 2009 2:17 am Reply with quote
oh right got ya so if i havent got glowplugs what have i got so i can change them
Back to top
 Alert Moderators
Jimbo1978
from United Kingdom
Thanked: 5 times
PostPosted: Mon Dec 07, 2009 7:24 pm Reply with quote
Lets clear a few things up here. The engine fitted in your van is a direct injection diesel and doesnt have any glow plugs. If the pump timing was out then it would be very poor when driving.
Things to look for are air leak in the filter head and poor compression.
The old 70/80ps engines suffered badly from this. Get it serviced but dont use 5w30 oil. Ford developed this oil but it was mainly for their zetec 16v and later tddi and tdci engines. If you van has done over 70k then use 15w40 mineral based oil(non synthetic). I supply a minibus company who still has 15 in his fleet and they go really sweet on 15w40. I'm not knocking anyone elses suggestions but 5w30 was always a bit light for this engine, even more so if its a bit worn.
Filter head aint expensive . bout 30 from ford and about 20 for an aftermarket. worth also getting compression checked just incase.
A quick thought is to check condition of battery and starter just incase.
they are good old vans so dont bin it
Best of luck
Back to top
The following user says thank you to Jimbo1978 for this useful post:
tommyl18 (8 Dec 2009)
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance All times are GMT
Page 1 of 1
Jump to:
Ford transit 2.0 2003 model struggling to start 2 80 Tue Jan 31, 2012 8:23 pm
ford focus 1.8 diesel wont start in the morning 5 500 Thu Dec 15, 2011 12:41 pm
Puegoet 206- Starting problems 1st thing in morning only 9 160 Mon Apr 30, 2012 4:23 pm
astra merit diesel struggling to start 11 4300 Thu Feb 07, 2008 8:04 am
Golf MK4 1.4 16V Mis fire rough running 22 6180 Fri Jul 05, 2013 7:52 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
