DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Combi Boiler Low Pressure when cold, high pressure when hot.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Trebor2Go
from United Kingdom
PostPosted: Wed Dec 02, 2009 7:15 pm Reply with quote
I have a Vaillant Turbomax Plus 828e.
All radiators are bled.
When the system is cold the bar pressure reads 0.8, but when running it climbs over the recommended 2.0 bar, reaching 2.2-2.3 bar, last year it never peaked above 1.5 when hot - any ideas why it should change this year.
Trebor
http://www.imagesetting.com/
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 918 times
PostPosted: Wed Dec 02, 2009 7:16 pm Reply with quote
expansion vessel needs recharging
see FAQ
Back to top
 Alert Moderators
Trebor2Go
from United Kingdom
PostPosted: Wed Dec 02, 2009 7:26 pm Reply with quote
Ahh, is the 'expansion vessel' a green rubber bag you inflate slightly with a bicycle pump ?
Back to top
 Alert Moderators
kevplumb
Thanked: 918 times
PostPosted: Wed Dec 02, 2009 7:38 pm Reply with quote
no see here
Back to top
 Alert Moderators
Trebor2Go
from United Kingdom
PostPosted: Wed Dec 02, 2009 7:53 pm Reply with quote
Hi, thanks for the reply, I remember now, a few years ago Vaillant instructing me to simply use my bike pump, and to let a bit of pressure out before hand.
Your FAQ suggests 'repressuring', - do I need to go through all that just to put a bit of pressure back in ?
Back to top
 Alert Moderators
MANDATE
from United Kingdom
Thanked: 130 times
PostPosted: Wed Dec 02, 2009 10:50 pm Reply with quote
[quote="Trebor2Go";p="1427617"] do I need to go through all that just to put a bit of pressure back in ?[/quote]
And what about the excess water? Where will it go?
Back to top
 Alert Moderators
Trebor2Go
from United Kingdom
PostPosted: Thu Dec 03, 2009 9:32 am Reply with quote
OK, well I found someone had turned the heating temperature dial up to full, which I hadn't noticed, would this have caused the Pressure dial to read above 2.0 Bar ? the temp. dial is at the 3/4 position now.
I still investigated the Expansion/Pressure Vessel, when I pressed the 'tyre valve' in no water (apart from maybe some condensed moisture) came out, but also no air seemed to come out either though - should I have expected a hiss of air at all ?
With the system hot I connected a bicycle pump and pumped 5-10 times.
Now when running hot the bar pressure measures roughly 0.75 Bar.
When cold bar pressure is reading 0.25 Bar.
I'm confused, the systems not leaking (not that I know of) - so where has all that water/pressure gone since pumping the bike pump. I know the min cold pressure should be much higher than 0.25bar. The installation manual doesn't give any Min. Bar Values for cold, is it 1.1 Bar ??
Back to top
 Alert Moderators
kevplumb
Thanked: 918 times
PostPosted: Thu Dec 03, 2009 9:35 am Reply with quote
follow the link and repressurise it PROPERLY first
Back to top
 Alert Moderators
Trebor2Go
from United Kingdom
PostPosted: Thu Dec 03, 2009 10:58 am Reply with quote
Thanks Kev,
If thats the procedure then I'll do it, let you know, mustn't forget my Fernox inhibitor, I've had some in the workshop for a few years, does it go off ?
Back to top
 Alert Moderators
MANDATE
from United Kingdom
Thanked: 130 times
PostPosted: Thu Dec 03, 2009 12:54 pm Reply with quote
The water won't have gone anywhere (unless you have a leak).
Water does not compress, air does!, You've pushed a bit more air in the air side and its pressure rises slightly. You've not created a larger air space for the excess volume of water, because you can't, until you remove some of the existing water.
The vessel is there to accommodate the extra volume as the water expands. The extra depends on the total volume of water in your system and the rise in temperature.
A system where the pressure starts at 1bar and rises to 2bar is normal. The problem arises when the higher pressure reaches 3bar which is when the pressure relief valve operates. So you would not want to start at 2bar and rise to 3bar.
Back to top
 Alert Moderators
Trebor2Go
from United Kingdom
PostPosted: Fri Dec 04, 2009 9:07 am Reply with quote
I followed the procedure, much better, but I'm unsure of the pressure in the expansion vessel - its roughly 10psi, the system only seems to expand by 1 Bar when its running hot ... does that sound OK - or could I have pumped too much air in.
Back to top
 Alert Moderators
kevplumb
Thanked: 918 times
PostPosted: Fri Dec 04, 2009 9:12 am Reply with quote
Back to top
 Alert Moderators
Trebor2Go
from United Kingdom
PostPosted: Fri Dec 04, 2009 10:07 am Reply with quote
Cheers Kev, last question, I've dropped about 20 litres out of the system (its got 8 rads in a Semi detached house) to do what was required, the system already had rust inhibitor in it, but I've only topped up with fresh water - should I put some more inhibitor in - or will it be OK as it is.
Back to top
 Alert Moderators
kevplumb
Thanked: 918 times
PostPosted: Fri Dec 04, 2009 10:10 am Reply with quote
put some in you can't overdose it
unless you go really silly
Back to top
 Alert Moderators
Trebor2Go
from United Kingdom
PostPosted: Fri Dec 04, 2009 10:31 am Reply with quote
Top tip ... will put some in. Cheers.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
High pressure cold supply - which boiler is best? 3 260 Fri Jan 16, 2009 5:26 pm
Gravity fed cold and high pressure hot - mixer tap? 3 60 Sun Jul 15, 2012 9:32 am
High pressure, combi boiler, how to release? 6 57520 Fri Mar 04, 2005 8:47 am
HIGH pressure on combi boiler - help! 14 3200 Mon Sep 05, 2005 2:28 pm
COMBI BOILER, PRESSURE TOO HIGH 6 6360 Tue Nov 25, 2008 9:25 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
