central heating/pump contantly running
3 Dec 2009
Kent
I have an intermittant problem where the living room heats up way in eccess of the setting on the room thermostat.
Not sure if its connected but when i turn off everything off at the programmer and the pump next to the hotwater tank keeps running. This happens with both the hot water only on or central heating on.
I have a honeywell 3 way valve next to the hotwater tank, is this the source of my problem?
Should the pump turn straight off when the central heating or hot water is turn off.
Any help would be gratefully received
Im no expert but i dont think it is a problem with the boiler. The boiler does not fire up when the timer is off. The boiler is a baxi solo pf50.
Should the pump contiue to run after to heating and cenral heat is turned off ?
So are you saying i need the pcb replaced?
Def not the valve next to tank?
no the valve sends a switch live to your boiler when a call for heat is made.
The boiler then sends power to the pump. The pcb has has a faulty relay
part number 231711BAX
