Beko Dishwasher using too much salt
4 Dec 2009
Staffordshire
Hi
I have a Beko DE3861FW dishwasher and it is using way too much salt. Everything inside has to be rinsed under the tap after the dishwasher finishes its cycle.
From what i can work out there is the regeneration valve and the water softner group that deals with the salt so unless there is any other components in the salt system should i replace these?
Feel free to correct me if i'm wrong or if you know what could be causing the excessive salt use?
Cheers Griff
