Dormer Roof Insullation
9 Jul 2007
Sussex
Hi People,
This might be a but hard to explain so bare with me....
I have a 1968 chalet dormer house. The upstairs dormers come out on a flat roof from the loft space remaining.
i have the usual problems, in the winter the house is freezing and baking hot in the summer! (isullation problems)
I have insulallted my loft and had cavity wall(for all the good that does me in a chaltet house)
Further inspection in my loft I notice that I have access to the dormer flat roof from the loft. Its only a small gap, but I can clearly see there is no insualtlion in there. This perhaps could be a big problem....
is it possible i can just get some more loft insullation and just try to cram it into the dormer roof through thr small gap in the loft?
I hope that makes sense? I guess i could try to draw the problem if needed
any advice would be greatful
you could try sliding some celotex or similar along the top of the ceiling but this is a very hit and miss operation.you need a 50mm airgap above the insualtion.not sure how you would know if youve done a complete job tho.
I was going to get some standard loft insulaltion and push it into the roof space.............
ad present in all my uptairs dormer roofs I have the plaster board ceiling, this gap and the the chipbaord felt roof. I would imagine this is a major problem for my heat loss? what do you think?
I would hope the external walls for the dormers are insuallted, but i have no way of finding out unless i cut into them
you will struggle to maintain an air flow with quilt type insulation.
can you take a socket plate off and look through there for insulation in the walls???.
if you electrocute yourself takin git off can you at least video it :LOL: :LOL:
Sorry for sounding dumb, but why is there a need for ventilation in there?
I believe you can get some loose insulation, would that work? Not sure boarding would due to the location
