I think the expansion vessel on our baxi boiler has gone, or at least needs recharging, as the pressure when running the central heating rises to about 3 bar
It then switches off due to the pressure then being 0 bar, this can be anything from 6 hours to 12 hours plus, so there is no set factor in how long it takes to drop to zero
Can anybody suggest how the hell I take the top plate and flue off so I can change the expansion vessel, I had a look at this last time when the air motor was making a terrible racket which turned out to be knackered rubber mounts making it vibrate on its mountings, I had to fix these in situ as I could get the top plate off no matter what I removed that looked like it was holding it all in place
I need to remove the flue so I can slide the expansion vessel out the back and drop a new one in, assuming it won't recharge and the diaphram has gone
Its fitted in a bedroom so access is very good all round
The boiler is roughly 3/4 years old
Thanks for any help, a manual would help greatly
