hi all , my hot water pressure has dropped and dont know why , if i bleed the hot water pump will that do anything . Sorry dont have a clue any suggestions would be great , thanks sean
Look for a silver braided hose connected to lever valves either end...Open one valve then the other to top up your system to between 1 and 1.5bar[/quote
Thanks for your reply but its my hot water pressure , when we first had boiler hot water came out of taps fast but now its a lot slower , any ideas . Thanks sean
Have you got a Scale reducer or Water Softener? if not I'll bet the hard Hetrforshire water has scaled up the plate heat exchanger, replacement is the best answer
