Good Morning,
I have had a problem with my Heating system - the system is exactly 3 years old this month (December 2009).
In a nutshell...The heating controls...these are:
Danfoss TP5000 Hard wired inside house that controls the Central Heating set at 20C on at 4.30pm to off (15C) at 8.45pm. The flame on the panel re-ignites the boiler if the air temp falls in the house.
Danfoss FP 715 Si in the garage (next to boiler and tank) that only controls the hot water we use; set from 6am to 6.20am and 5.50pm to 6.20pm.
These are both wired into the fused spur powered Danfoss terminal box as is the boiler, pump, tank thermostat and the actuator valves.
This is my problem:
The Danfoss TP5000 ignites the boiler at 4.30pm and heats the house up nicely.
If the program is run through its entirety the flame disappears and the boiler keeps going....the temperature of the radiators keeps increasing and the house is like a sauna.
I have to switch the boiler off at the fused spur panel (as the pump sill keeps going if I turn the boiler off at its switch - Which is strange??) to get the heating off as the Danfoss TP5000 will not control the boiler at this point,
However I have had the panel tested and even swapped it with my next door neighbour (they have same system) there is no fault on mine and the same problem occurs with the perfectly working Danfoss TP5000 from next door.
The next thing I was advised on was the actuator 2 port valve on that controls the central heating. I have changed this with one I borrowed again from next door, this was a perfectly good Danfoss He24 2 port valve actuator.....again the same problem persists....I now have 2 Danfoss He24 valves...that presumably both work fine!!
Finally, the worst thing of it all, when I try to demonstrate the problem I have with the continuous running of the boiler even when the TP5000 has told the boiler to switch off is:
When I manually turn the TP5000 on to fire the boiler and central heating it does fine, I can leave it 10, 20, 30, 40 minutes then turn the thermostat to the non-flame off temperature e.g. 15C, 18C etc... The boiler turns off nicely...
I am now stuck on what is happening.....Is it the thermostats inside the boiler not operating properly or something I am totally missing???
The Central heating and Hot water work fine, it’s the boiler not shutting down when it is told to by the Danfoss TP5000 that is doing my nut in!!
Thanks for any support!!
This is my problem:
