DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Insulate outside tap?
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Vicario
from United Kingdom
Thanked: 1 time
PostPosted: Tue Dec 15, 2009 5:08 pm Reply with quote
I had a tap fitted outside over the summer. It is fed from a tee off the rising main under the kitchen sink and then through the wall and fitted under the kitchen window. I can turn off the supply via a dedicated stop cock. My neighbour reckons that his didn't freeze even during last year's cold snap and that he has never bothered to insulate it. I have switched off the water supply, but is my neighbour correct about insulation? The house is centrally heated until about 10.30 each night and then again from 6am.
Back to top
 Alert Moderators
powell30
from United Kingdom
Thanked: 129 times
PostPosted: Tue Dec 15, 2009 5:39 pm Reply with quote
He was lucky......isolate via stop cock and then open the tap, this will allow any freezing water an expansion route and stop the pipe splitting......or insulate
Back to top
 Alert Moderators
Chukka63
from United Kingdom
Thanked: 81 times
PostPosted: Tue Dec 15, 2009 5:50 pm Reply with quote
Back to top
 Alert Moderators
JonB
from United Kingdom
Thanked: 24 times
PostPosted: Tue Dec 15, 2009 6:25 pm Reply with quote
I tie an old gardening glove round mine.
JonB
Back to top
 Alert Moderators
kirkgas
from United Kingdom
Thanked: 458 times
PostPosted: Tue Dec 15, 2009 8:12 pm Reply with quote
no need for a tap during the winter so why risk having the water on? isolate and open tap till the spring comes round again, does your neighbour have the pipe insulated between the cavity as well, he was lucky!!
Back to top
 Alert Moderators
Master of None
from United Kingdom
Thanked: 16 times
PostPosted: Wed Dec 16, 2009 12:46 am Reply with quote
Don't see how these cover can work. There is water in the tap and pipe. It could be subject to freezing temperatures for days at a time. No amount of insulation is going to keep the tab above freezing for that amount of time. Isolate and open tap as advised above.
Back to top
 Alert Moderators
TicklyT
from United Kingdom
Thanked: 336 times
PostPosted: Wed Dec 16, 2009 6:47 am Reply with quote
Vicario wrote:
....... My neighbour reckons that his didn't freeze even during last year's cold snap .....
Maybe it did freeze, and he was just lucky it wasn't damaged?
Back to top
 Alert Moderators
Chukka63
from United Kingdom
Thanked: 81 times
PostPosted: Wed Dec 16, 2009 7:39 am Reply with quote
unless you have a beloved motorcycle and wanna wash all the salt off it after a good blast icon_lol.gif
Back to top
 Alert Moderators
kirkgas
from United Kingdom
Thanked: 458 times
PostPosted: Wed Dec 16, 2009 8:38 am Reply with quote
very true, that takes me back, i actually have a hot and a cold outside tap for washing the car, filling the paddling pool, just make sure they are plumbed in with easy access to the valves so that the tap can be easily put on and off
Back to top
 Alert Moderators
WDIK
from United Kingdom
Thanked: 56 times
PostPosted: Wed Dec 16, 2009 11:31 am Reply with quote
in sweden as standard the tap is inside with a 2 ft shaft to control.
Back to top
 Alert Moderators
Chukka63
from United Kingdom
Thanked: 81 times
PostPosted: Wed Dec 16, 2009 1:20 pm Reply with quote
Back to top
 Alert Moderators
75pete
from United Kingdom
Thanked: 17 times
PostPosted: Wed Dec 16, 2009 1:52 pm Reply with quote
It feels like it today!
Back to top
 Alert Moderators
adlplumbing
from United Kingdom
Thanked: 312 times
PostPosted: Wed Dec 16, 2009 7:17 pm Reply with quote
i was alway fit isolation and drain off so it can be drain down
as well double check vavle
(god do hate acky brick in this area)
Back to top
 Alert Moderators
tdesnos
from United Kingdom
Thanked: 4 times
PostPosted: Wed Dec 16, 2009 8:59 pm Reply with quote
don't insualte. there i said it! everyone goes well over the top with it in this country. as the guy said we're not in sweden. if you're worries, just leave it open and turn it off from the inside the water can drain out then. think about how many uninsulated garden taps out there and how many call outs have i had for frozen/ split taps? none. don't lose any sleep over it mate.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Cupboard in front of radiator - any way to insulate it? 4 80 Sun Nov 25, 2012 5:38 pm
insulate central heating pipes 2 100 Mon Aug 26, 2013 6:58 pm
the need to insulate plastic pipes? 2 80 Sat Sep 14, 2013 9:11 pm
Insulate heating pipes or not? 2 60 Fri Jan 20, 2012 12:11 pm
Insulate your condensing pipes! 20 320 Sun Dec 11, 2011 5:34 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
