We have a Bosch Excell SGS43A12GB-27 dishwasher. Bought s/h from a charity shop, it had been PAT tested etc. Upon install I ran a Finish cleaning bottle through it and I believe it worked - bottle had got rid of it's contents etc. But then ran a wash and everything was still dirty.
Listened and fiddled and deduced that no mains water was going in though sounded as if pump was running. After a bit of a trawl round the net I decided to brave it out and got the toolbox from the cupboard.
Drained the waste and fresh water from the bottom first off and cleaned any muck out of the waste area. took the kick panel off which was a real bugger. Especially as there was nothing behind it!
Then removed the side panels. All looks well inside with no wires off, burning etc. On the side with the distribution tube there was some condensation in the tubes and black residue in the top left chamber but nothing seemed untowards. Both microswitches were free and moving.
Ran the machine with no sides on a rinse cycle. No water came into the distribution tubes at all, so switched to a main cycle whilst it was running - nothing again. So I put a meter over the two terminals on the mains inlet solenoid and there seems to be no current to it - just the odd, millisecond long pulse on a sporadic basis.
So my question is what gives the current to the solenoid? I'm assuming it is the fault not the solenoid. And also when I was checking the solenoid terminals and switching the machine on and off, the pump (which was always running when the machine was powered up) started sounding very rough. Have I ruined it by running it after draining the water tanks in the bottom?!
Many thanks.
Many thanks.
