Potterton profile 80e which pipe is flow and return?
when you run boiler from cold what 22mm pipe heats up first..........
thats the flow
this one is being swapped for a promax as it's dead so my guy just wanted to double check. Called Potterton and they said flow is always on the left – so fingers crossed.
flow in 22mm pipe first one on the left,return last pipe on the right in 22mm
fairly standard on all baxi,potterton boiler range
Shouldn't the flow and return on an 80e be 28mm?
