changing a 306 front fog lamp bulb
13 Dec 2009
Does anyone know how to change a near side front fog lamp bulb on a 1998 peugeot 306 please? Not sure how to access the front fog as there seems to be a plastic cover covering the underneath of that area. thanks
The plastic undershield or wheel arch liner has to be dropped before you can get in, which is a bit of a pain.... The bulb is bayonetted into place so turn it to the left to get it out. It may be the plain H1 bulb but some come with a wire attached so extract it before buying a new one.
John :)
Yes the plastic bit is a splash guard and this needs to be removed before you get the bulb out, either a 20 or 30 torx bit, can`t quite remember now, and yes some have wires attached and some just have a spade connecter on the back of the bulb, but they are not bayonetted, they have a spring fitting, and this will need to be pushed in and moved to one side, then it will swivel upwards allowing you to remove the bulb, and don`t touch the glass of the new bulb as sweat or dirt from your fingers will cause a hotspot on the bulb and it will burn out quicker, by the way you only need to take the two torx screws going through the bumper out, then you should be able to pull the guard back and away enough to get your hand up in there.....hope it helps.....
