DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Interior Door Frame
This topic originated from the How to page called Fitting the new exterior door frame
Click here to return to the page called Fitting the new exterior door frame.
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
  View previous topic :: View next topic
Author Message
DAVIDAS
from United Kingdom
Thanked: 0 times
PostPosted: Sat Feb 05, 2005 11:33 pm    Post Subject:
Interior Door Frame
Reply with quote Thanks
I am fitting a new interior door frame and have removed the old one. The problem is that I have measured the depth of the opening and it ranges from 130mm to 135mm. Looking at the old frames they were all 130 and any gaps were filled which when painted meant that this did not show. The problem I have is that I am going for the natural look and do not want to paint the frames but stain/wax the natural wood instead??
My second problem is that I am fitting old English style latch doors and ideally do not want to cut notches out of the frames that I install. Can anyone suggest a frame style that could solve this problem??
Thankyou very much for any help.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
nstreet
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 06, 2005 11:24 am    Post Subject:
Buy your timber wider than the max width of the frame and fit. Then use a router with a flush trimming bit to follow the profile of the wall. You can then fit the architrave.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
How much/long to fit an Interior Door 4 480 Wed Apr 02, 2008 9:56 am
interior door size 75.7 cm 3 260 Fri Aug 15, 2008 1:03 pm
Broken interior doorhandle and door is shut? 2 420 Mon Feb 05, 2007 11:58 am
Replacing an exterior door with an interior one. 4 520 Thu Feb 21, 2008 6:47 pm
1981 by 610 mm (78 by 24 inches) glazed interior door 3 480 Wed Aug 15, 2007 2:57 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
