DIYnot
Local | Network
   DIYnot > Forums
Local | Network
high electricity bill - is it because my timer settings?
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
glider26
from United Kingdom
PostPosted: Sat Dec 26, 2009 11:21 am Reply with quote
We are a couple living in a rented 3 bed house with a boiler and tank equipped with an immersion heater, both located in the loft. My elec bill for the 6 weeks to Oct 9th is quite high (121 for 970 units) and I suspect it's because of the way I set the immersion heater.
We have a thermostat in downstairs and a timer (one for CH, one for DHW) in the old airing cupboard. Also in this cupboard are two switches, one for the boiler and one for the immersion heater. The CH timer has it come on twice a day, 2 hours in the morning and 5 hours at night (assuming the thermostat is tripped by a low temp). So far so good. The DHW at the moment though is only on for about 20 minutes per day, just before we wake up. We take a shower each/day on average, and sometimes less than that (because we shower at the gym, not because we're filthy icon_smile.gif ).
I'm not familiar with the immersion heater logic. Does it come on to maintain a certain temp in the tank? In which case should we have the DHW timer stay on longer so as to use gas instead of elec? How long for?And does the tank get topped up with cold mains water as it is depleted by DHW demand?
Thanks for any help.
Back to top
 Alert Moderators
big-all
from United Kingdom
Thanked: 949 times
PostPosted: Sat Dec 26, 2009 11:33 am Reply with quote
if you have gas central heating your immersion should be switched off
if not you need to find out if your on economy 7 or other off peak supply
the hot water stays layerd the cold is fed in the bottom and dosnt mix much so if you use half a tank off hot you dont finnish up with a full tank of luke warm water you finnish up with roughly 1/2 a tank off hot warm then cold with only the middle few inches mixing
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 218 times
PostPosted: Sat Dec 26, 2009 11:40 am Reply with quote
As above, the immersion heater is there as an emergency back up.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1467 times
PostPosted: Sat Dec 26, 2009 11:42 am Reply with quote
if your immersion heater, and the pipes around it, are very well insulated, it should not cost that much, unless the thermostat is faulty and it is overheating or running continually. In this case you would notice the water is uncomfortably hot. Or unless you have a leak or a running or dripping hot tap or pipe. An immersion heater uses about 3kWh per hour at about 10p each, say 30p per hour when running. Look at the insulation , and test the water temp with a thermometer, and tell us what you find
however, as Al says, if you have a gas boiler, let that heat the hot water as well. Gas costs less than half the price of electricity.
If you have other electrically-heated appliances, such as fan heater, tumble drier, dishwasher, washine machine, these all use about the same 3kW when the heater is running.
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 918 times
PostPosted: Sat Dec 26, 2009 11:45 am Reply with quote
Back to top
 Alert Moderators
glider26
from United Kingdom
PostPosted: Sun Dec 27, 2009 7:46 am Reply with quote
Thanks, I've switched the immersion heater off and increased the time during which the boiler heats up DHW to 1h/day. I'll increase it if I get complaints...
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1467 times
PostPosted: Sun Dec 27, 2009 10:38 am Reply with quote
it's still worth checking the insulation and the water temperature
A modern boiler will heat a modern cylinder in about 20 minutes and it will stay fairly hot for 24 hours if properly insulated.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Range Tribune HE quick question (electricity usage increase) 12 140 Sun Jun 26, 2011 8:24 pm
Vokera eclipse boiler tripping off electricity 2 40 Tue Jun 21, 2011 12:01 pm
Boiler constantly pulling 50 watts electricity? 13 240 Fri Nov 25, 2011 1:06 pm
Electricity meter - White Meter 3 80 Tue Jun 05, 2012 4:24 pm
Glow-worm 24cxi Cutting out after lost of electricity supply 6 100 Sat Jun 09, 2012 4:49 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
