SL Compact Exit Timer Problem
Hi
No 17 is further to the right you may have to lift the top cover up/off to see it
Also the reason your alarm was going off when tripped is either due to dead or missing battery in your panel, looking at your picture you dont have a battery at all
You can pick one up for around £10
Son that's what the two wires hanging down 'should' be attached to then... A battery? Makes some sense!
Why sort an where would I buy one?
Thank you again by the way!!
Heres the battery you need
Look at this on eBay:
12 VOLT 1.2AH ALARM BATTERY ( 12V 1.2AH - 1.3AH )
http://bit.ly/IhZ1VQ
Having this connected will stop it going off when you have power cuts or trips
Bought! Thank you! Should be arriving in the next few days by the looks of it!
Next step to reset it...
Yes you now need to reset it
You will need a small length approx 6" of wire to connect them two numbers together to reset, but first remove that top cover and remove the wires from them two numbers you are going to be using, bear in mind your reconnecting them after doing the reset
When doing reset you neednt screw this length of wire in you just need to hold it where the screws bits are for a very short time, you will hear alarm beep on reset, it only takes seconds.
In this order
Removes wires from them terminals
Put power on (push fuse back in)
Use length of wire to touch them terminals both at same time obviously
The alarm will reset
When you do apply the power chances are youre alarm will sound but will stop once you reset it, this can all be done in 2-3 seconds
Once you have reset it leave power connected and soon as your battery comes attach it straight away
Hope this makes sense to you
You're a gent! Thank you.
I take it I do need to wait on the battery arriving before i do this?
and.. how do I reset it after the alarm goes off... Is that a case of downloading the main manual for the alarm?
Thanks!!
You can reset it now as long as when you apply the power you leave it on dont disconnect it or you will the alarm sound again
Programming it is easy
OK - I've established that my box isn't numbered as 17 and 27 but IS labelled up as PA and SET so we're all good on the connectors front...
When I connect up the PA (no.17) it is a double connecter with a U shaped wire connecting the two terminals... and the SET terminal has nothing going into it.. So as I see it, there are no wires going into these two terminals at present. See pic below...
Should there be wires into these terminals?
Thank you ...
Simon
Thats fine
Remove the loop shaped wire then
Place your bit of wire in the correct points and push that fuse in
Alarm will make a beep to confirm reset
Then stick that u shaped wire back where it came out
Thanks...! Alarm now reset.. Can't believe I've had the darned thing for going on 5 years with the fuse pulled out! Will send over my email address...
And now reprogrammed! Most impressed with your help and with the ease in which my alarm has now become a working feature of the house! :) THank you thank you!
Just to pick your brains with one more thing if I may... I have two cats and as such, the PIR's I imagine will go off with them wandering the house. I saw some 'pet friendly' PIR's online.. Are they worth it? Do they work..? etc etc
Thank you again,
Kind regards
Simon
Glad to hear you alarm pretty much sorted
When the battery arrives put your alarm into engineer mode before removing the front cover, connect battery and replace cover, job done
Dont forget to change the engineer code and user codes from default
Regarding pet PIR i cant really comment as ive no pets, but they must work if setup correctly
You could part set the system or setup double knock.
They say dusl tec pirs are the best but im not sure if suitable with pets
Let me know how you get on
