peugeot partner van hdi 2001
20 Sep 2008
Yorkshire
hello all anybody out there know where the priming pump is. broken down twice in 2 days. think i may have a leak in the fuel line as both times its been facing uphill. cheers in anticipation. ps have changed f filter
not worked on cars for a while but was the the van running alright before you changed the fuel filter? the primer pump will be near the filter
The priming pump is either a push down one located by the filter - if its a Oval type -
Or A bulb type pump located in the line after the filter ( Round filter type!)
Hope this helps!
