My Ideal Isar HE35 boiler recently broke down, no lights/display, no noise no response at all when switched on. I called a guy out to fix it, who installed a new PCB. The transformer on the old PCB had burned out. There's no other visible fault on the PCB, or sign of water getting into it. The boiler then started up, giving fault code H 5 . This code wasn't in the manual, so he spent quite a while examining different bits of the boiler and scratching his head. I Googled the fault code, it turned out he hadn't set the jumper on the PCB which specifies the boiler model. After setting the jumper heat and hot water worked. after he left I bled the radiators (including 1 that I had recently re-fitted after wallpapering), pressurised the system up to 1.5 bar (installation pressure is 1-2 bar) then went out, leaving the heating running to warm up my cold house.
I came back 1 hour later, to find lots of water coming out of the bottom of the boiler. I turned the power off at the wall and called the guy back. He returned the next day, and discovered that water was leaking from the automatic air vent in the heat exchanger. He says he can't fix it, and suggests I call Ideal to sort it. He insists that he couldn't have caused the leak, although he can't explain what's caused it.
Question is:
Could he have damaged the valve looking for the cause of the fault code?
Could the freezing cold weather have caused the problem,perhaps the condensate drain to an outside pipe freezing up?
Could it be some other underlying fault that's been triggered when I pressurised the system after bleeding?
The boiler's about 5 years old, and has never been serviced.
All thoughts and ideas appreciated.
Question is:
